RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   prop question on eagle 580 (https://www.rcuniverse.com/forum/arf-rtf-75/9738330-prop-question-eagle-580-a.html)
cap580pro 05-16-2010 09:03 PM
i have a cap 580 with a saito .82 engine. im currently running a13x7 pop and would like to upgrade a little... What prop do you reccomend i use for solid aerobatics and mild 3D flight???
nitro wing 05-17-2010 12:22 AM
RE: prop question on eagle 580
A 6" pitch blade could do better, maybe APC 14x6 or graupner/vess 14x6,if you are using MA,drop it and try something else. props will make ALL the diff.
ProScaleRc 05-18-2010 11:37 PM
I'm running an OS .75 AX spinning a 14x5 ACP
House2twist 05-19-2010 01:15 PM
Try an APC 13x4 W prop. The wide blade will give you more thrust for aerobatics but slow your stop speed (not that you want to use this thing as a racer).
ChuckW 05-19-2010 02:12 PM
I ran a 13x4 on my YS-63 powered Cap-580 and it was outstanding. The .82 might even pull a 15x4.
pvelit 06-05-2012 05:54 AM
I need some advice: I have a YS91 engine and I want to see if I buy this plane, could I use the YS91 or is it too big for it? I just don't want to spend more money on a new engine if I can use the one I have...
Any comments or suggestions will be appreciated.
Thank you
nitro wing 06-06-2012 10:12 PM
Modern YS are lighter than most other 4 strokes. if your .91 weighs in similar to the saito .82, and pysically fits, go for it. Its not a good 3D plane, if that is what you want, put the YS on one of the popular profiles instead
pvelit 06-07-2012 05:53 AM
Thank you for responding! The YS91 weighs about 150 grm more than the Saito .82 ... Also, it a bit bigger in dimension, a couple of mm here and there, but not too much bigger, I think it should just fit in the cowling. Also, maybe I can put one of the servos back in the tail to counteract the extra weight in front... that way the plane is not too nose heavy.
