Ask the Expert Sal - Electric Airplane Advice Here is your chance to ASK SAL, the expert for all your electric flight related questions. If you are not Sal, please do not answer questions in this forum.
Need help picking a replacement motor.
Old 09-01-2013, 03:28 PM
bushong572
My Feedback: (59)
Default Need help picking a replacement motor.
I recently purchased a used E-Flite Carbon Yak with a bad stock motor (EFLM7300 BL25 Brushless Outrunner 1000KV). Is there a cheaper alternative to another stock motor ($70.00) with similar performance? The stock motor has a 5.5mm shaft and uses the X mount. I would like to be able to use the stock mount and the aluminum spinner that is on the plane.
I'm new to electrics and would appreciate any help.
