LI-PO Ballancing
LI-PO Ballancing
Hi!!
I'm just about to take my first plunge into LI-PO/Brushless. I've got a Seb Art Katana 30E with the included Hacker s30 motor and ESC, and have some 2200 MAH LI-POs for power.
I've seen ballancers advertised. Could someone explain exactley how they work, how I use one, and the consequences if I try and get by without one?
Could someone also recommend what type of connectors would be best for this set-up?
Thanks guys!
Thanks guys!
FL
RE: LI-PO Ballancing
RosscoW:: I've been do'in without a balancer for 22 charges on my 3c lipos , folks charged lipos for years before balancers were around with good results, but I too would love to here a good reply here as I'm a bit perplexed myself, your bub, scoooper
ORIGINAL: RosscoW
Hi!!
Thanks guys!
Hi!!
Thanks guys!
Here are a few tips to keep you batteries in best shape and longest life.
Only dishcarge 75% of capacity. If you have a 2000 mah capacity only use 1500 mah...no more....
To do this you have to time you flights and see what you put back into the battery. For example if you have a 2000 mah pack and you fly for 10 minutes and have only used 1200 mah, you are safe. One your next flight you can try another minute more flight time or so and read the charge again. DO NOT RELY ON YOUR ESC! By the time your cutoff works you will have most probably damaged the battery. It only takes one over discharge to damage a battery
Store the batteries at less than 100% charge. You should store at 50-75%. I simply read the voltage as I am charging. In the case of the 3-cell pack I wait until I am at 12.4 volts and shut off.
Only go to approx 95% for a full charge. This will add many more charges to your battery pack. Most chargers start with constant current, then when the full voltage is acheived switch to constant voltage with a charge cutoff at 50 milliamps. Stop your charger when is reaches 150-100 milliamps.
More to follow...
FL
salnsp::: I'm on my way to my LHS post-haste!!! thank you for your lipo for dummies exp, I've been read'in up on it but your simple reply was just the info I was look'in for!! thanks for your insightful an simple explanation that made it right through my thick hogg'in-box! your grateful bub, scoooper PS rossco, thanks for the thead your bub, scoooper
No problem! It can be very confusing. So many products, so many changes. Li-poly batteries are changing constantly and its hard for even companies like us to keep up.
Thanks sal, that's great. My ballencer has been ordered.
WRT not over dis-charging the cells, how do you determine how much you've used on a particular flight? By the amount of charging the pack nedds next charge?
Regards
Ross
Regards
Ross
The best way to figure how much you can use for a particular airplane is to fly the aircraft for a certain amount of time, then charge it to see what you used. Be conservative! Lets say you have a 4000 mah battery pack and you fly for 10 minutes and you use 2500 mah. Now you only want to use 75% of the capacity max so that gives you 3000 mah to work with. 10 minutes flight time at 2500 mah is 250 mah per minute which means you could go to 12 minutes flight time.
IA
I have two of these balancing chargers and I wouldn't use anything else on my expensive batteries.
http://www.fmadirect.com/products.htm?cat=45&nid=4
Perfect Lipo balancing charger for dummies.
And no, I do NOT work for these guys.
Happy Landings.
Happy Landings.
MI
ORIGINAL: Natch
Happy Landings.
Happy Landings.
You are most welcome. Actually I am finding this forum a lot of fun. I certainluy know how confusing the electric stuff can be. I like to help figure out motor systems for modelers. This hobby is all about having fun and I know that if I can get the right setup for your model or help with any of the problems that can crop up in this pretty technical hobby, it might put a smile on someones face. That's good enough for me.
