Ask the Expert Sal - Electric Airplane Advice Here is your chance to ASK SAL, the expert for all your electric flight related questions. If you are not Sal, please do not answer questions in this forum.
Motor Amperage
Old 02-27-2007, 08:46 PM
Default Motor Amperage
Is the amount of amps that a motor draws a function of its internal resistance? Or is it a matter of what size prop it's spinning?
Old 02-28-2007, 02:24 PM
Default RE: Motor Amperage
The amount of amps a motor draws is a function of the load. This would include the idle amps. The prop puts the load on the motor. The amount of amps a motor uses is a function of Kv, Idle amps, Internal resistance, Prop size, voltage and current from the battery.
Old 03-16-2007, 10:09 PM
So everything being the same..... When you change to a smaller prop does the amp draw go up or down?
Old 03-17-2007, 10:24 AM
Changing to a smaller prop decreases the load on the motor and hence reduces the amps. This is assuming the pitch stays the same. For example if you have a prop such as a 10 x 5 and went to a 9 x 9 prop, the load would most likely be higher due to the increased pitch.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
