Ask the Expert Sal - Electric Airplane Advice Here is your chance to ASK SAL, the expert for all your electric flight related questions. If you are not Sal, please do not answer questions in this forum.
"Forming" a pack....how do you do it?
Old 03-08-2007, 08:43 PM
Default "Forming" a pack....how do you do it?
I have a new 1450mah Hydrimax Rx pack and i want to be sure i take good care of it and get the most out of it. I've heard of people "forming a pack" on the first charge(s?) but I'm not sure I know what that means. Can you enlighten us?
By the way, congrats on teh success of this forum! Looks like there are a lot of us out there with questions and we appreciate your help!
Dave
Old 03-10-2007, 12:19 PM
Default RE: "Forming" a pack....how do you do it?
I think what you are talking about is break-in. This pack is NiMhd? If so, the best way to break-in a NiMhd pack is to charge and discharge the pack several times (4-6). You would charge to full capacity. the first charges should be at a slow rate (1/10 c). This means charge at 1/10th the capacity of approximately 145 mah. You only need to be in the ballpark so around 100-150 mah will do. Then you discharge to 1.1 volts per cell or 4.4 volts. Then charge again. repeat this cycle for 4-6 times then move up to 1C for the rest of the charging if you so choose. You can stay at 1/10C if you like.
Many of the commercial chargers today have charge and discharge cycles. They usually will have instructions so you could also follow these.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
