Ask the Expert Sal - Electric Airplane Advice Here is your chance to ASK SAL, the expert for all your electric flight related questions. If you are not Sal, please do not answer questions in this forum.
engins shutting down
Old 03-12-2007, 09:23 PM
mrbee's Avatar
Default engins shutting down
[img][/img] hi sal just put togrther a b2 made by gws. a gws r6n reciever, ics -480 speed controller, pluss a 15 amp v tail mixer also by gws, the problem is the engines are shutting down past 3/4 throttle please help and thanks bill
Old 03-13-2007, 09:44 PM
Default RE: engins shutting down
That is caused by a voltage drop. This is usually in the setup og the speed control. Try to setup the speed control with soft cutoff if this is available. The other thing could be the battery. If the battery cannot handle the amps demanded by the motor prop combo, it will show a voltage drop and this will cause the speed control to shut down.
Old 03-14-2007, 03:06 AM
mrbee's Avatar
thanks sal,i did only have a 4.8 700 battery in it
Old 03-16-2007, 11:14 AM
Only 4.8 volts? I am surprised that the speed control even worked at all. Going up to a more normal voltage for electric flight should take care of the problem.
Old 03-16-2007, 03:41 PM
mrbee's Avatar
thank u very much
Old 03-17-2007, 10:25 AM
You are most welcome
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
