Ask the Expert Sal - Electric Airplane Advice Here is your chance to ASK SAL, the expert for all your electric flight related questions. If you are not Sal, please do not answer questions in this forum.
cermark Islander conversion
Old 03-29-2007, 11:03 AM
My Feedback: (132)
Default cermark Islander conversion
Sal I have a twin engine Cermark Islander with two 05 electric motors. I plan on using a 3s 4400 lipo to power both motors. Will this give me enough power and if so what would the duration be and what size ESC will I need? Thanks, Phil
Old 03-30-2007, 10:33 AM
Default RE: cermark Islander conversion
The batteries sound fine, but I cannot tell much without knowing what motor you are using. I cannot look up the airplane because the Cermark site is closed for maintenence. You will need two esc's but the amperage rating will depend on the motor output based on the motors and the requirements of the aircraft. The batteries sound ok. What is the output rating for the battery?
Here is what I need to go further:
Airplane
Wingspan
wing area
flying weight
Motors
Kv (rpms per volt)
Io (amps)
resistance (mohms)
If I already know the motor I can find out the info
Old 03-30-2007, 10:46 AM
let me know what you do have for info and we will go from there.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
