Ask the Expert Sal - Electric Airplane Advice Here is your chance to ASK SAL, the expert for all your electric flight related questions. If you are not Sal, please do not answer questions in this forum.
raidentech cessna 337 25 size
Old 04-11-2007, 07:22 PM
Default raidentech cessna 337 25 size
Sal,I have been doing glow for over 40 years but with the brushless motors and light weight batteries I am considering trying electric on this.my question is what do I need in the way of motorsgear drive if needed,props,esc and batteries to do this?I have read that new maganese batteries are safer than lipo's and think that would be the way I would like to go.know for the 2nd part of this is what would all this equipment weigh?
Old 04-11-2007, 07:27 PM
Default RE: raidentech cessna 337 25 size
saw you may need specs so these are off the sight
Home > R/C Cars & Planes > ARF RC Gas Airplanes > Twin Engines > Blue Cessna 337 Twin 25 - 55" ARF Twin Glow/Electric Powered Radio Remote Controlled RC Multi Engine Aircraft
Electric 2-CH 3-CH 4-CH ARF Micro Size Warbirds Sailplanes Upgrades Repair Parts
Nitro Gas Aerobatics Warbirds Trainers BiPlanes Scale Twin 15-35 40-50 60-80 90-160 Pilots Parts
Item: Gas_CessnaSkymaster25Blue
Retail price: $399.00
Our price: $129.00
Quantity:
Availability: Usually ships the next business day.
Useful Links:
Enter the Cessna 337 Skymaster 25 Fuel or Electric Powered. A Prop in Front, A Prop in Back--No Worries about engine meltdown...This intriguing aircraft is every r/c enthusiasts' dream. It's a twin, with the engines placed on the centerline so there is no adverse yaw in an engine-out situation. Pretty nifty huh? It's so cool that even in a real life Cessna 337, the FAA even has a special inline thrust twin rating which acknowledges that the planes are easier to fly.
Wing Span : 55 in / 1400mm
Wing Area : 426 sq in / 27.5 sq dm
Flying Weight : 5 lbs / 2270g
Fuselage Length : 43 in / 1090mm
Engine Required : 2Strock 0.25size or Outrunner Brushless 450T - 500T
Radio Required: 4 channels 5 - 7 servos ( use Outrunner Brushless only 5pcs servos)
Old 04-11-2007, 11:37 PM
My Feedback: (12)
alqwad's Avatar
Please join us over here...
[link]http://www.rcuniverse.com/forum/m_5321427/anchors_5321427/mpage_1/key_337/anchor/tm.htm#5321427[/link]
Old 04-23-2007, 12:04 PM
any recommendations at all?
Old 04-29-2007, 08:52 PM
Sorry for taking so long. I will have a recommendation for you on Monday. Still I can tell you that two medium sized outrunners will work fine. I would go with something in the size of an AXI 2820 ot Hitec HC3522 or Hacker A30-10L. I would run either on or two 3-cell battery packs. With 5 lbs two of these motors whould be able to give you 8-9 lnbs of thrust at 40-50 amps. I would consider going with 4500-6000 mah battery capacity so you could get 15 minute plus flights.
Old 05-05-2007, 07:53 PM
sal what about this motor from ak models,seems like it is close to your recommendation,but I am not that familliar yet with electric motors.
Motor R35A-1
MSRP: 89.00
AK-Models Price: $45.00
Shipping Weight: 0.20 pounds
14 available for immediate delivery
Weight:105g
RPM(KV):860( 400W)
WorkingCurrent:12-30A
Size:35x36mm Φ:5 mm
Suitable Props:10x5.5 to 11x6
WorkingVolt:6-15V Efficiency:79%
Suggest Controller: at least 40A
Old 05-15-2007, 10:33 PM
In order for me to give you an educated answer I still need some specs. To do an analysis I will need to have not just the Kv but the idle current (expressed as Io) and the resistance (this is usually given in Milliohms) Still from the specs that you gave me it sounds like the motor is too smal (2.20 lbs is only 3.2 ounces which sounds too small) the operating voltage of 12-30 amps sounds too low. I would want a set of motors that would go to 50 amps each continuous as a minimum.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
