Ask the Expert Sal - Electric Airplane Advice Here is your chance to ASK SAL, the expert for all your electric flight related questions. If you are not Sal, please do not answer questions in this forum.
What can I do with this little motor??
Old 04-11-2007, 07:32 PM
Default What can I do with this little motor??
Designation: 1208425L
Turns: 25
Max Amps: 5.5
Resistence: 0.3160
RPM/V: 5866
IO(A): 0.6
Shaft Size: 1.5mm Diameter / 6mm Length
Weight: 17 grams / 0.60 oz.
Dimensions: 12 mm Diameter x 31mm Long
I'd prefer an airplane suggestion.
Thanks.
Rick
Old 04-19-2007, 01:24 PM
Default RE: What can I do with this little motor??
Certainly you can use it in a ducted fan. One of the EPP fanjets that we sell would work with this. They are made for a GWS fan that takes this sized motor. Tale a look at the L159 Alca on our website.
Here is the address: http://www.nesail.com/detail.php?productID=5401
let me know if this sounds good to you or you want to go another way
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
