Ask the Expert Sal - Electric Airplane Advice Here is your chance to ASK SAL, the expert for all your electric flight related questions. If you are not Sal, please do not answer questions in this forum.
Crystal information needed
Old 05-09-2007, 10:21 PM
Campy's Avatar
Default Crystal information needed
I am trying to find a "mini dual conversion receiver crystal" on 72.490
(channel 35 ). This crystal will be used in a Turborix 8 channel dual
conversion PPM receiver.
I have contacted the few ads I have seen for the Turborix dual conversion
receiver and they do not sell the crystal separately.
I received the receiver as a gift and there is no information with it
and I do not know where it was purchased. The crystal that is presently
in the unit has "WFLY" on the tag. a 5/32" spacing between the pins.
Pin diameter APPEARS to be about 1/32". Bottom flange width is 5/16",
case width is 1/4",thickness is about 3/32" and case height from the
bottom of the flange is 5/16".
Any ideas/suggestions on what might fit/work ?
Old 05-15-2007, 10:13 PM
Default RE: Crystal information needed
Sorry! I can only suggest that you contact the manufacturer of distributor, if they cannot help you I suggest getting another receiver. The problem is that receivers are designed differently and use different Harmonics and sizes for the crystal. There many be a crystal from another manufactuere that would work but without knowing the design it would be impossible to determine this.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
