Ask the Expert Sal - Electric Airplane Advice Here is your chance to ASK SAL, the expert for all your electric flight related questions. If you are not Sal, please do not answer questions in this forum.
Aerobatic control problems.
Old 06-15-2007, 04:28 PM
Default Aerobatic control problems.
Hiya! Aerobatic plane problem. Setting up 3D Profile 3 servo plane and cant get control surfaces working correctly. Non digital TX 6 channel rx - when I give right/left movement on stick the ailerons move up/down but also the rudder moves left or right. Elevator ok up/down movement on stick. Motor ok on left stick up/down for on/off proportional. Sounds like servos on wrong rx pins or should this happen to give extreme controlled flight. Help!![][&o]
Old 06-15-2007, 05:20 PM
Default RE: Aerobatic control problems.
Sounds like you have a mix turned on in your transmitter. Most transmitters ailerons on ch 1, elevator ch 2 and rudder on 4, but like I said, there's probably elevon mixing switch in the wrong position. If it's a non computer radio, look at the switches near your servo reversers. If a computer radio, find the mixes and fix 'em.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
