Go Back  RCU Forums > RC Helicopters > AutoGyros
Blade hang angle >
Blade hang angle
AutoGyros All about autorotational flight, sport and scale autogyros! User friendly!
Blade hang angle
Old 02-10-2003 | 08:51 PM
DICKEYBIRD's Avatar
Default Blade hang angle
OK, I got the blades carved for my small homebuilt gyro project and am now working on the hub....a poly "flapper" with 15 deg. delta hinging. Does any one know the pros & cons of blade travel limits? Do the blades ever need travel downwards past zero coning angle ie: droop down below the hub at all? What about upwards travel limitation?
Thanks for any thoughts on this subject.
Old 02-22-2003 | 08:35 PM
Technically a model would fly if the blades were allowed to flap up-down quite a bit.... since once they autorotate and in flight they will seek their own level. But, it is not necessary for them to flap down below zero/level and thus strike the model, so they are generally limited to zero down. They need to be allowed/restricted to flex/hinge upward maybe a max of about 20-30 degrees simply to make it easier to obtain autorotation for launch... otherwise they may initially flap virtually straight up and make it impossible to spin up. I have also seen a model lose its blade "upper" limiter in flight and a gust of wind actually folded the blade vertical and loss of control occured.
So to answer the question: zero down and 30 degrees up is a good guide.
