HELP Autogyro Guru's!!!
1 Attachment(s)
Hi There ....
I am taking on the research, of what I hope will be, a most interesting autogyro project. I am primarily looking for sites, information and any related material for an electric pusher autogyro. I expect that the finished project would be fairly large in size. Possibably as large as if it were powered by a 35 to 60 size glow engine. The overall idea is to take the McDonnell XV-1 and covert it from a VTOL to a trike gear autogyro. For those of you who may not have seen this aircraft ... attached is a pic. Any and all input would be appreciated!! Thanks for your help |
RE: HELP Autogyro Guru's!!!
I think it ought to be doable.. Tri gear and the wing. With electric motors today with li-po's. SHould work OK.
Not sure if anything on www.autogyro.com will help. AeroBalsa blades with a delta head. Good luck, keep us updated. Jim |
Make a super simple junker first of the approximate size/weight.
Then when you get all the trim settings, make it scale. My vote is to go with a heli head, heres a 3 blader http://www.heli-world.com/Merchant2/...ct_Code=CN1113 and the matching swashplate http://www.centuryheli.com/products/...?currentid=199 mick |
try this, has some useful info at the bottom of the page...
http://www.myunclewillies.com/gpage5.html Sean |
| All times are GMT -8. The time now is 03:38 PM. |
