RCU Forums
-   AutoGyros (https://www.rcuniverse.com/forum/autogyros-191/)
-   -   eclips7 problem (https://www.rcuniverse.com/forum/autogyros-191/4932131-eclips7-problem.html)
asi1 10-30-2006 02:17 AM
eclips7 problem
I HAVE THE ECLIPS7 AND I HAVE SOME PROBLEMES WITH THE HEADING HOLD GYRO.
I CONECT THE GYRO TO THE CHANEL7 TO USE THE SWITCH FROM HEDING HOLD TO NORMAL
IN THE EPA OF CHANEL 4 I POOT THE VALUE OF 100% TOO BOTH SIDES .
THE VALUE OF NORMAL fligt condition IS 80% AND IN ST1, ST2 IS 90% (IN THE GYRO MODE )
THE VALUE OF THE MIXERS ARE INHIBIT INCLOOD THE VALUE OF THE REVMIX .
FOR NOW THE VALUE OF THE EXPO IS "0"
IF I TURN THE RUDER TOO THE LEFT OR RIGHT AND BRING BACK THE ROODER STICK TOO CENTER THE LED ON MY 401 ( FUTABA ) GYRO ARE FLASHING .(keep flashing after i leave the stick in the center)
IT SEEMS LIKE THE GYRO COOLD NOT FIND THE NUTRAL OF THE SERVO AFTER I USE THE ROODER STICK.
I TRI TO SOLV THE BROBLEM BY POOTING IN THE EXPO "-70" AND IN THE EPA OF CHANEL 4 80% ONLI WITH THAT VALUS THE GYRO FOOND THE NUTRAL AGAIN IDONT UNDERSTAND THIS THING I NEEED HELLLLPPP ( I CaNOT DOO ANI PIROET WITH THIS VALUS )
I HAVE TOO SAY THAT I DONT UNDERSTEND THE MEANING " FOR REVERSED GYRO THE SETINGS WILL BE THE OPPOSITE"
THANKS
rcflyerfl 10-30-2006 02:58 PM
RE: eclips7 problem
ASI1,
You are in the Auto Gyro section.. You need to ask your question in the Heli section..
Good Luck,
Jim
