Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
NEW Sanwa M12
Old 09-03-2012, 08:29 PM
banzaihobby
Default NEW Sanwa M12
New from Sanwa M12 now at Banzai Hobby
Break the Record!!!
Feel the alternation of generation in R/C industry.
Newly equipped 4x higher spec CPU compared to former world champion model M11X. Brand new M12 realized to double it's analysis ablility.
Latency minimized operatbility and innovative features, gurantee M12 as the new flagship of new generation.
As the saying goes time is money, M12 responds almost "Zero-Latency" which human being has ever sensed before.
Extremely high response which exceed the former radios. Driving comfotable with no stress.
Customable setting allows drivers to change their driving condition instantly.
Racing Mode Setting
(Able to record D/R, Trim, Curve record. Drivers easily change their setting depends on their driving condition by single touch.)
Weight Reduction
Succeeded in weight reduction by changing internal structure.
Fullfilling logger and PC link functions.
Drivers be able to keeping track of telemetry data recorded from throttle and steering operation.
Enables to access the PC with exclusive cable.
New Features:
*CAR Type Select : 10 Categories
*Racing Mode: Able to change driving status in a single touch
*Logger: Able to send your data to the PC
*Monitoring: Share data with your friend's Transmitter
*PC Link: Able to read and write your data to the PC
*Dual Steering: Able to set your rudder angle individually
*Best Fit Setting: Able to set your best condition
*Curve Setting: Able to fine adjust 9/18 point curve
*LCD Display: 128×256 full dot LCD display
*Custom Menu: User friendly Menu structure
Evolution From M11X
*DMS Setting:Directly read your registered model at the launch
*TH 5:5 mode: TH neutral pulse 1.5m sec
*Point AUX: integrated Maximum 6 points AUX
*MOA MIX : Respond to 2 motor throttle
*4WS MIX: Respond to Front and Rear steering individually
*SPEED Setting: ST/TH point, direction setting available
*MODEL Sorts Setting: Model Order can be sorted as you like
*Offset Setting: Starting Position, Break Storke Cancel Function
*Ch Set Menu Setting: Setting menu for every CH
* Weight Reduction: 100g less than M11X
Sanwa M12
Get in Quick as these wont Last!!!
Please come an Join us on Facebook for Weekly Specials and Updates!!!
Banzai Hobby Team
