Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
NEW Tamiya Hop Ups!!!
Old 11-25-2012, 03:33 PM
banzaihobby
Default NEW Tamiya Hop Ups!!!
New from Tamiya a Wide range of Hop-Ups now at Banzai Hobby!!!
Front Skid Angle Spacer Set - RM01 (w/4mm Titanium Screws)
These spacers enable fine ground clearance and skid angle adjustments of the RM-01 chassis' front suspension, enabling a wider range of setting adjustments as well as increased suspension attachment rigidity.
TRF201 Sus Weight Block (0)
This metal suspension block (approx. 30g) replaces the kit-standard N3 parts to help provide greater front wheel traction and increased rigidity.
TRF201 Sus Weight Block (5)
This metal suspension block (approx. 30g) replaces the kit-standard N3 parts to help provide greater front wheel traction and a skid angle increase of 5°.
Lightweight Shaft - Front-Middle
Made from hard- coated aluminum, this lightweight, durable front middle shaft offers efficient power transfer and improved throttle response. It is compatible with a wide variety of pulleys to allow for creating drift settings on the TA-06 chassis.
Lightweight Main Shaft
Made from durable aluminum, this lightweight main shaft offers efficient power transfer and improved throttle response on the TA-06 drivetrain. It also features hard coated surfaces for improved durability.
Steel Bevel Gears - For TA06 Gear Diff Unit
Replace the kit-standard plastic gears (GV1 and GV2) with these metal gears to allow your car to handle tough driving conditions such as rally driving with a high-powered motor.
Compatible with TA06, XV-01, and FF-03R chassis.
Also usable with TRF417 Gear Differential Unit II (Item 42197).
Please Join us on Facebook for Weekly updates and Specials!!!
Banzai Hobby Team
