Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Banzai Hobby Support Forum
Reload this Page >
Wrap-Up Next Yokomo Drift Package FR-D Conversion Kit V1.1 (Front Motor, RWD!)
Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
Old 01-30-2013, 06:43 AM
banzaihobby
Default Wrap-Up Next Yokomo Drift Package FR-D Conversion Kit V1.1 (Front Motor, RWD!)
NOW available for Pre-Order!!!!
Secure your order now and do not miss this opportunity!!!!!
Wowza! Now FR-D Conversion has upgraded to High Traction Model!!!
******V1.1********
Available in Four Colors!
FR-D V1.1 Conversion Kit - RED
FR-D V1.1 Conversion Kit - Blue
FR-D V1.1 Conversion Kit - Silver
FR-D V1.1 Conversion Kit - BLACK
Newly designed SSF Main Chassis & Upper Deck using new material! These newly designed chassis will give you better roll hence, better traction. Furthermore, you can add adjustable setting weight (Option Parts) direct to Upper Deck.
Totally NEW Style!! Just like real Drift car!!
* Front Engine > Motor
* Real Wheel Drive!
* Check out the new gear unit!
This Conversion will take you to "NEW Experience" for RC Drifting!!
This conversion kit include:
* SSF Main Chassis
* SSF Upper Deck
* Graphite Support Plate
* Graphite Upper Brace with Front Gear Unit (Aluminium Mounts, Aluminium Pinion gears, Carbon Composite Pinion Gears etc).
* Front Aluminium Suspension Mount
* Aluminium Steering Post
* Aluminium Adjustable Steering Link
* Aluminium Battery Holder & Stopper
* Axle Shaft
* Screws
* Nuts
Require:
Yokomo Drift Package Series
* If you are using Type-C, you require a bit of modification.
You don't have Drift Package Chassis?
DP-DP8 Drift Package Basic
This chassis is perfect to use with FR-D!
__________________
www.banzaihobby.com
Online Hobby Shop direct from Japan!
Join us on Facebook!
