Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
NEW Active Hobby Accessories!!!
Old 04-01-2013, 07:03 PM
banzaihobby
Default NEW Active Hobby Accessories!!!
New from Active Hobby some new Accessories !!!
Corresponding Universal joint 49mm Long Suspension Arm
Use when adjusting stretch more than 3mm from genuine aluminum suspension arms
· Maximum steering angle of 55 degrees! Universal drive shaft is dedicated drift has been designed with the goal of steering turning angle up first.
· Expanding the diameter of the axle cup 12mm for both steering angle and durability, ensuring a sufficient thickness.
Has adopted a high-strength steel material stuck to the material has been used in the GP model.
Steering angle, as well as up, stripped-down design their own parts not needed also contribute to weight reduction.
Dog bone is set to 45.5 mm, are also available to negative camber.
• Supports (such as VDF) system TAMIYA TA05.
TT01 Drift Counter Unit Ver1.26 Rear (17T-35T)
TT01 Drift counter unit Ver1.26 Rear (1.26 ratio 17T-35T)
TT01 Drift Counter Unit Ver1.76 Rear (17T-25T)
TT01 Drift counter unit Ver1.76 Rear
1.76 ratio 17T-25T
Spare Gear Set (17T/35T) Ver1.26
Spare Gear Set (17T/25T) Ver1.76
BEC and Servo 120mm Single and Twin Extension
Ideal for running LED's or Fans, Or for the Twin set up to Run Both LED and Fan Set up of the same Wiring Loom!
Please come Join us on Facebook foe Weekly Specials and Updates!!!
Banzai Hobby Team!
