Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
Tamiya TT-02
Old 05-20-2013, 10:05 PM
banzaihobby
Default Tamiya TT-02
New from Tamiya is coming to Banzai Hobby is the Fresh an Exciting TT-02
***Products will be shipped as soon as we receive them in stock (after 24th May)***
Key new features:
Brake disc-shaped, wheel hubs which add to the chassis' highly realistic appearance.
The 4-wheel independent double wishbone suspension features friction dampers and uses identical L/R suspension arms and uprights for ease of assembly and maintenance.
Both the motor and the battery are longitudinally-placed in the ABS resin chassis for excellent balance.
Upright assembly can be changed to give the chassis an extra 4mm of travel for Rally racing
[http://banzaihobby.com/Tamiya-58560]Ferrari 458 Challenge - TT02[/url]
Specification
Scale : 1/10 scale
Construction type : assembly kit
Terrain use : on-road
Drive-train : 4WD
Drive type : shaft
Drive line : dog bone
Differential type : gear
Suspension : fully independent double wishbone
Steering mechanism : bell-crank
Shock damper : friction damper
Shock damper material : plastic
Tire type : rubber
Tire tread : slick
Body material : Polycarbonate
Chassis material : plastic
Electronic Speed Control (ESC) : NOT Included
LED Light buckets : yes
LED lights : no
Motor : 540-brushed type
Bearings : plastic bushing
Adjustable camber : fixed
Adjustable toe angles : front only
Adjustable ground clearance : yes
Adjustable gear ratio : yes
Adjustable wheelbase : yes
Adjustable track width : yes
Adjustable shock angle : yes
Special feature 1 : Easy to build entry level kit
Special feature 2 : Includes window masking seal for easy painting
Special feature 3 : Highly detailed body with vinyl stickers
Special feature 4 : Symetrical suspension components
Special feature 5 : Beveled main chassis for improved cornering clearance
Special feature 6 : Brake disc shaped wheel hubs
Special feature 7 : Wheelbase: 257mm/251mm adjustable
Special feature 8 : Compatible with 380-size motors
Special feature 9 : battery compartment compatible with square shaped batteries
Requires A : 2-channel radio gear
Requires B : 7.2 battery & charger
Requires C : polycarbonate paint
Please come Join us on Facebook for Weekly Specials and Updates!
Banzai Hobby Team
Old 05-23-2013, 04:16 PM
banzaihobby
Default RE: Tamiya TT-02
Tamiya Ferrari 458 Challenge TT02 and Spare Parts  is now in Stock.
Any Pre-Orders While be Shipped Shortly
Banzai Hobby Team
