***NEW***Yokomo Competition 1/12 Pan Car Kit
The New Yokomo Competition 1/12 Pan Car Kit is now at Banzai Hobby!!!
This is the Yokomo R12C3 Competition 1/12 Scale Pan Car Kit. Debuted at the JMRCA nationals, the Yokomo RC12C3 took the TQ and win in the hands of factory ace Naoto Matsukura, and further proved its worth by putting all four Yokomo team drivers in the A-Main! The R12C3 features a front end design that has never been used on a 1/12 scale pan car. with independent friction dampers, a front wire-type anti-roll bar and a unique bell crank type steering system. The rear end remains unchanged from the previous models using a conventional link-type design with a redesigned thrust type heavy-duty ball differential and a carbon fiber axle. With these updated features, the R12C3 corners like no other pan car available and is guaranteed to set a new standard in the class.
Features:
Front Friction Damper
Adjustable front suspension
Main Chassis
High precision thrust bearing type rear ball differential
Direct drive RWD
Front double wishbone suspension
Flexible Rear Suspension
Rear link suspension
Light weight differential ring
Carbon long rear shaft
Floating Rear Bulkhead
Light weight 37mm Front wheel & Center offset 38mm Rear wheel
Adjustable rear height
Full Ball Bearings
Get in quick to Avoid Disappointment as these will SELL FAST!!!
Also check us out on Facebook for Weekly Updates and Specials
Banzai Hobby Team
Features:
Main Chassis
Direct drive RWD
Full Ball Bearings
Banzai Hobby Team
