Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Banzai Hobby Support Forum
Reload this Page >
Wrap-Up Next Kondo Custom VX Rear Suspension Arms
Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
Old 10-31-2013, 02:56 PM
banzaihobby
Default Wrap-Up Next Kondo Custom VX Rear Suspension Arms
Wrap-Up Next NEW Kondo Custom VX Rear Suspension Arms now at Banzai Hobby!!!
Realization (zero) lever ratio of 1:1 by innovative structure. Kondo custom foot VX suspension system appearance.
2.5mm/3mm shaft specifications lineup. Can be attached to any drift model in the suspension arms width 30mm.
The suspension structure of the conventional Kondo custom foot VX suspension system is the drift for rear suspension system to achieve (zero) lever ratio of 1:1 was difficult.
Increase significantly the shock stroke, taking advantage of best performance of shock, to improve road surface tracking performance, traction performance.
※ silver model is the silver in both the suspension arms, knuckle.
2mm shaft supplied to fix the knuckle and suspension arms.
Bearing is not attached. Please prepare the same as Drift package (outer diameter 10 / inner diameter 6mm).
Get in Quick to avoid Disappointment!!!
Banzai Hobby Team
Old 10-31-2013, 02:58 PM
banzaihobby
A Video on how the Arms works
http://www.youtube.com/watch?v=3ow3Z...ature=youtu.be
