Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Banzai Hobby Support Forum
Reload this Page >
OVERDOSE Divall Chassis Kit [PRE-ORDER]
Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
Old 08-17-2014, 06:38 PM
banzaihobby
Cool OVERDOSE Divall Chassis Kit [PRE-ORDER]
Banzai Hobby is now Taking Pre-Orders on the OVERDOSE Divall Chassis Kit
Second RC Drift Shaft Drive Chassis released from OVERDOSE, named Divall!!
Using Center Motor & Center Battery lay out with shaft drive chassis.
Front and rear center drive shaft turned opposite direction in order to prevent reversed torque. Innovative idea and downside of shaft drive chassis is no longer!! As many people like direct drive feel of RC drift chassis but used to compromise the handling. With OVERDOSE Divall, you can enjoy both shaft driven chassis direct drive feeling as well as perfect balanced handling like belt driven chassis.
Using OVERDOSE innovative Bevel Gear lay out in order to minimize reversed torque and perfect balance. Bevel gears are made out of steel.
Using, Front Ball Diff. and Rear Rigid. Gear Ratio: Front 40T/15T, Rear 38T/19T. F&R Ratio is 1.3
Newly designed F&R Gear Case. F&R Upper Bulkhead using aluminum.
OVERDOSE
Divall Chassis Kit (Purple)
OVERDOSE
Divall Chassis Kit (Red)
This is PRE-ORDER
If you place pre-order, we will do our best to secure your products for you and ship them to you as soon as we receive them in stock.
If you make a pre-order, as usual, we will throw in goodies for you
Get in quick and don't miss this opportunity as only limited quantity is available.
ETA: End of September 2014. This may change without any notice by manufacturer.
Old 09-29-2014, 01:47 AM
banzaihobby
Divall Front One-Way Set in Black
Divall is off for the front one-way unit. By replacing the front ball diff of standard kit, drift control performance will improve to achieve a quick steering response. Adopt φ6mm one-way clutch of large capacity, we have succeeded in both of the goodness of cut and high durability also adhered to the dimensions of the press at the time. Standard equipped with a one-way adjustable cup joint OD unique, it can slide to a maximum 2mm outside the cup joint by a spacer further. Can be addressed without changing the length of the drive shaft even if you change the camber and tread.
***Bevel gear is not included in this product.**
Please Check us out on Facebook for Weekly updates and Specials
Banzai Hobby Team
