Tamiya Wild One is Back!!! (in Stock!)
</p>http://banzaihobby.com/images/58525.jpg?rand=430460786 <span class="font-med">The Wild One was originally released in 1985. 2012 marks the year it has been re-released to hobbyists who missed the kit the first time around.</span><span style="font-size: small;"> </span></p><div class="font-med-red-bold">Specs and Features</div><span class="font-med"><ul>[*]Scale: 1/10 scale[*]Construction type: assembly kit[*]Terrain use: off-road[*]Drive-train: 2WD[*]Drive type: gearbox[*]Drive line: dog bone[*]Differential type: gear[*]Suspension: fully independent double wishbone[*]Steering mechanism: bell-crank[*]Shock damper: oil-filled damper[*]Shock damper material: aluminum[*]Tire type: rubber[*]Tire tread: pin spike[*]Body material: Clear Polycarbonate[*]ESC NOT INCLUDED[*]ESC type: <span class="font-med">NOT INCLUDED</span>[*]LED Light buckets: no[*]LED lights: no[*]Motor type: 540-brushed type[*]Bearings: shielded ball bearing[*]Chassis material: FRP[*]Sticker material: vinyl[*]Internal gear ratio: N/A[*]Adjustable camber: fixed[*]Adjustable toe angles: front only[*]Adjustable ride height: yes[*]Adjustable gear ratio: n/a[*]Adjustable wheelbase: fixed[*]Adjustable track width: fixed[*]Adjustable shock angle: fixed[*]Anti-squat adjustment: n/a[*]Droop adjustment: n/a[*]Special features: 1150 size bearings included x8[*]Requires: 7.2 battery, charger[*]Requires: polycarbonate paint[*]Requires: radio gear[*] <span style="font-size: small;">Live your childhood dream and don't miss opportunity to purchase <a target="_blank" href="http://banzaihobby.com/radio-control/tamiya-rc-cars/tamiya-kit-set-electric-off-road/58525-wild-one-off-roader"><font>Tamiya 58525 Wild One Off-Roader </font></a></span></p>[/list]</span> |
RE: Tamiya Wild One is Back!!! (in Stock!)
OK Wait; Tamiya is Banzai Hobby? Just trying to get this straight......
Hi there.
Thanks for the message.... We are just online shop based in Japan and we sell Tamiya products but not Tamiya lol Check out our website yo! Hope this helps. Thanks. |
