ENELOOP batteries
RE: ENELOOP batteries
Check out Amazon. When you do, be sure to look at all the various options as prices can vary quite a bit between the packages. Best one I found is 16 AA's at $39.xx
I've ordered from them a couple of times, fast delivery and best prices I've been able to find.
CA
Rodney,
I have not been able to find Eneloops with tabs. Have you?
Have you tried soldering the tabless batteries?
Were you successful?
Any suggestions on the process?
KW_Counter
KW_Counter
ORIGINAL: KW_Counter
Rodney,
KW_Counter
Rodney,
KW_Counter
CA
Rodney,
I must confess I am not familiar with fluxing with electronics - plumbing, yes.
This is mostly because the solder usually has flux in it.
Your concept sounds solid. What kind of flux should be used?
Any recommendations? Where to buy?
KW_Counter
KW_Counter
Rodney,
KW_Counter
Rodney,
KW_Counter
Rodney,
KW_Counter
Rodney,
KW_Counter
