Rayovac VS Eneloop
Moderator
RE: Rayovac VS Eneloop
One is a top quality hobby grade battery and the other is designed to be cheap enough to sell at retail to power cameras. To give a straight answer though, there really is nothing like an Eneloop. Unless you need the slow discharge characteristic, standard Sanyo Nimh's will hold their voltage better at higher amp draws and may last a bit longer too.
