Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Reload this Page >
What power supply for Cellpro 10XP
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 04-11-2012, 07:02 PM
rcguy5
Default What power supply for Cellpro 10XP
Hey guys,
I plan to charge 2 5s 6600mah packs simultaneously at a 2c charge rate with my 10XP. I don't know for sure but doesn't this charger put them in series which means more load on a power supply. Would a 12v 47amp supply be enough or do I have to go to 24v. Whether the 10XP charges 2 5s packs as 2 5s packs or as a 10s pack I think makes a big difference on what power supply. What do you think?
Any help would be appreciated.
Mike
Old 04-17-2012, 06:31 AM
startazz
Default RE: What power supply for Cellpro 10XP
To be honest i'm not 100% sure but i think you might just be able to do it on the 12v 47amp supply but if i was you i'd wait until you knew 100%
I'll leave a link to what i think would be up to the task,if you do go on the link go down the page until you just get passed the price tab and you will see a tab saying Discussion,ask in there as i'm sure someone will help you out better than what i can,thats if no one here has already,good luck.
http://www.hobbyking.com/hobbyking/s...8V_60amp_.html
Old 04-17-2012, 08:17 AM
Goldenduff
12vx47= 564watts.
If you are charging 5cell lipos (18.5v) the above power supply, if 100% efficient would give you 30amps (564watts/18.5v). That 30amps is more like ?25amps due to heat loss.
To charge 2 6amps batteries at 2C you need 24amps.I would say that power supply but would work but not a lot of head room.
Correct me if I'm wrong
Old 04-18-2012, 04:40 AM
TampaRCGuy
My Feedback: (282)
ORIGINAL: rcguy5
Hey guys,
Mike
To get the 600 watts you need a 30V PSU.
Old 04-18-2012, 05:44 AM
rmh
rmh's Avatar
ORIGINAL: rcguy5
Hey guys,
Mike
Having been there - even the best deep cell batteries take a real jolt when charging the 5 cell packs - -the best bet for field charging thes FAI packs - a small quality generator
Indoor charging with the 110 volt charger is best IF you can use the max voltage allowable on my Cellpro 10 -thats 15 volts- so buy a power supply which is a switching type and capable of max inputs on the 10xp
Old 07-22-2012, 02:38 PM
Peter_OZ
Banned
not one from hobby king !!!!!
