?? On Power Supply
My Feedback: (21)
?? On Power Supply
All/Red,
Got my hands on a 450W ATX power supply. One thing I do not understand is about the load resistors on the 5V side. I picked up a 2 pack of 10 ohm 10 Watt Sandbars to use. Now, since it is a 450Watt PS, do I need to use both resistors? Do I put both in series with one another (on the one 5V wire), thus giving me 20 ohms? Where do the Power Good and Power on wires go to?
Also, do I really need to use heatsink compound to attach them to the side of the PS case? Or can I just use zip ties?
I appreciate your help. I would like to get this up and running so I can use my new triton!!
Banned
My Feedback: (9)
Re: ?? On Power Supply
Originally posted by NOVAflier
All/Red,
All/Red,
Connect Power good to + 5 volts also.
For detailed instructions see:
http://www.marcee.org/Articles/PCPowerSupply.htm
VA
?? On Power Supply
Hi,
Take your two resistors and lay them side by side, now twist the wire leads on each end together so that instead of 4 leads you now have two leads, now connect one of these leads to the +5 volt and the other lead to ground.
That's it
That's it
Banned
My Feedback: (9)
?? On Power Supply
Works GREAT, But the two resistors get really hot. Why? Any way to decrease this?
Banned
My Feedback: (9)
?? On Power Supply
Red, I don't mean to sound like an idiot, but I don't know what you mean by "both elements wired". Can you explain please? Sorry.
