Turnigy Nano-tech 5C charge rate, really?
I just got my new turnigy nano tech 4.5 amp 25-50C packs for an Emaxx project I am working on. On the back it sayes not to charge them over 5C. I have been charging my lipo's at 80% C since day one. Can I really charge them at 5C? is that going to shorten the life of the packs? Has anyone else tried 5C yet? I charged one at 6 amps and it did not even get warm and it charged pretty quick. I would like to charge them really fast but I cant afford to buy new ones too often.[img][/img]
My Feedback: (325)
RE: Turnigy Nano-tech 5C charge rate, really?
When I "charge like everyone else" I charge my nano tech at 13.5C and they warm up a little bit. (just about how I like them) It might shorten the life of them , and right now it only has 100 cycles or so on it. I'm confident that 5C will be no problem.
Why not charge at 2c and monitor temp. Then 3c, then 4 stop at 5c or before if they get warm?why not charge at 2.5c then 3 then 4c etc. stop at 5 or before if they get warm?
My Feedback: (325)
ORIGINAL: Goldenduff
If pack is being charged for the first time of the day or session AND is already at a storage voltage then the rate can be very high, fast. A warm pack OR one that is nearly discharge all the way needs to have a slower , lower rate. Using a higher CC/CV point requires a lower current to match the same speed/temp.
thank you for your insight. My power supply is rated at 8 amps, does that mean that if I charge at 8amps the drawl on the power supply is 8amps?
My Feedback: (325)
Only if the input and output voltages are equal. (give a little for waste like 10%)
In your particular case since your input voltage is around 12 volts and the output is around 8 volts then the current being pulled from the ps is always going to be around 66% of the charge current. Remember that waste though? It's probably around 70-75% of the charge current.
