Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Reload this Page >
The ABSOLUTE best field charger!
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 09-16-2003, 10:36 AM
Thunderhead
Thunderhead's Avatar
Default The ABSOLUTE best field charger!
Im needing a new field/home quick charger. I have several types of planes and radios. I have a plane with 2 seperate batteries (1 ign & 1 for rec) I'm looking at the Hobbico MKII for it's ablity to charge 2 batt's at once, but it doesnt cycle them. Also I would need a DC power source for home. (I've already done the PC power source conversion, I'm not impressed) The triton from GP looks great but that $130 price and it looks like you get to only charge 1 thing at a time. Money really isn't a problem, but I want to be able to by a charger that does EVERTHING I need it to do, and dont want to buy another in a year just because I didnt know they made it. Whats eveyone use, and what else is out there?
Derik
Old 09-16-2003, 02:48 PM
MHawker
My Feedback: (16)
MHawker's Avatar
Default RE: The ABSOLUTE best field charger!
Look in the product announcements section for the new charger that's coming out. It's called a Miniron Mobil. It looks very promising.
Old 09-19-2003, 02:52 PM
laryboy
USE THE MK2 FOR FIELD CHARGER AND LEAVE IN YOUR CAR. BUY CHARGER THAT RUNS OFF AC FOR YOUR SHOP AND LEAVE IT IN YOUR SHOP.
Old 09-19-2003, 08:59 PM
Falcon_az
My Feedback: (25)
Consider the FMA Super Nova.
Review on Red's site.
http://www.rcbatteryclinic.com
Old 09-20-2003, 03:48 PM
Ernie Misner
Ernie Misner's Avatar
The Sirius smart charger makes the best field charger in the world. There is NOTHING to set on it, simply plug it in. On the other hand the Triton requires some programming and only charges one pack at a time. I have both and love them for their (different) qualities.
Ernie
Old 09-20-2003, 08:29 PM
captainG
captainG's Avatar
I'll second Ernie on that. The SIRIUS CHARGERS are the worlds best. I bought a Pyramid AC 12v power supply so I can use it at home without running down my field box. Sirius also sells their own. The one thing I love about the Sirius chargers is no buttons!
[link=http://siriuselectronics.com/]Sirius chargers[/link]
[link=http://1stopcbshop.com/s-cart/form.phtml?g_intCatID=66]Place to buy a power supply[/link]
Old 09-21-2003, 10:58 PM
kadet
I use the Charge+ from Hughes RC, it does 4 battery packs at once.
www.hughesrc.com
Old 09-22-2003, 07:08 AM
Forgues Research
My Feedback: (7)
Forgues Research's Avatar
Wow, that's a strong statement. I presume you have tried all the rest to make such a bold statement..
Old 09-22-2003, 07:19 AM
SeacretsOceanCity
SeacretsOceanCity's Avatar
Get 2 tridents 135 a pop will do it all
Old 09-22-2003, 10:22 AM
sideshow
sideshow's Avatar
The one thing I love about the Sirius chargers is no buttons....
There is also no display.....
I want to know exactly what is going on...during and after charging. If my ECU pack needs more charging than usual I want to know it so I can figure out why....
I have not used a Triton but have heard pretty good things about it.
I have 2 Orbit V6's and I recommend them. They are not cheap, but they can charge everything that's available right now...and you can update the eprom (software) when another technology become available. I updated the one I bought 2 years ago for $15...it's as cutting edge as the one I bought two months ago....pretty cool.
Old 09-22-2003, 07:25 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Hi Derik,
What type of batteries (i.e. NiCd, NiMH, Li-poly) and capacities do you use in your Tx and planes ?
Old 01-02-2004, 04:07 PM
Boeing
My Feedback: (145)
Its worth your time to go to: www.aerografixs.com and investigate the Sommer Miniron Mobil charger.
I've been using one for a couple of months and it outshines any other charger currently on the market.
Dave
Old 01-02-2004, 10:57 PM
rctrax
ACE digipulce is the best all around charger I"ve found. charges six different batterys of any type or any size simontaniously 85.00 at Radical RC. Uses household current. buy another field charger for the field.
Old 01-08-2004, 10:11 PM
outa control
My Feedback: (22)
I use this cycler/charger and do not have any complaints so far. This can be used either in the home or at the field but I mainly use it at home. It only can charge two packs at a time which is all that I need. I have a quick field charger which I use on my flight box. Check out this link and see if this will fit your needs.
[link=http://www.hobbypeople.net/review/350370man.htm]cycle pro[/link]
Old 01-09-2004, 01:57 PM
Ernest-T
My Feedback: (7)
Ernest-T's Avatar
If your stars are in the right quadrant, you have your 4-leaf clover and lucky rabbits foot, and you don't need one anytime soon, you might consider getting on the list for an Alpha 4. Has 4 charging ports, does NiCds, and NiMh, and runs of AC and DC (including with your car running, so you can charge on the way to the field).
Old 01-10-2004, 06:41 AM
spitflier
spitflier's Avatar
You should look at the Schulze This does everything including hook up to your computer and chart the charge times, memorize charging data for every pack, It does li-pos, Ni-Cd, Ni-Mh, and gell cells http://www.schulze-elektronik-gmbh.de/index_uk.htm. I hoping it would cook me breakfast but that's the next model up
Old 01-11-2004, 05:46 PM
shaunrbell
shaunrbell's Avatar
I second the Schulze charger. Being a former Alpa4 owen, i needed something with more capacity.
- 4 ports, 2 @ 5.5amps and 2 @ .3amps
- 28ah gell cells for field use
- dual 10amp power supply for home use (plug and swith on side)
- even air and propane lol!
Shaun Bell
Old 01-12-2004, 09:05 AM
isaac
My Feedback: (19)
My understanding is that you need 20 amp power supply to run the shultz.
Old 01-12-2004, 09:41 AM
Forgues Research
My Feedback: (7)
ORIGINAL: isaac
Besides, the Shultz only has 2 output, so you need two of them to get 4 outputs, where as the Miniron Mobil has 5 output in one unit.
Roger
Old 01-13-2004, 12:42 AM
GalenB
My Feedback: (18)
For field charging I use the Sirius Pro chargers. I'll not claim they are the best, but they sure are easy to use, no buttons or settings to mess up! They are also flexible -- I modifed one of them to charge two receivers batteries instead of one receiver and one transmitter. Since everything is automatic it charges whatever I plug it into properly. With my Coleman car starter, it has 2 outputs, and my 2 Sirius chargers I can charge 3 receivers (2 receiver batteries and ignition) and one transmitter at the same time. I use a SuperNova for cycling. I've not found the need to take it to the field and prefer to cycle my batteries at home...
Sirius also makes a decent cycler and offers an inexpensive 12v bench power supply.
Old 01-13-2004, 01:27 AM
c/f
Roger
This type of comment points out the misinformation that abounds with chargers. I learned the hard way after securing a Alpha 4 that it is way overrated and promptly sold it as new.
The maximum amperage output in DC amps of all the top chargers is in the range of 6.5 amps DC to a reported 8 amps DC. This amperage is an absolute constant so wether you have 1 port to 4 ports you only get a total sum of the max divided amongst all the ports. You "DO NOT" get max potential across all ports or a total of 20+ amps.
So heres a scenario to consider, if you use two ports and they divide half the max potential then it takes twice as long to charge across two ports than if you had just charged them twice as fast in one port which ones better???
My favorite is the Schultze, the Miniron?? has a very low output voltage/cell count potential for my needs. You must be able to spell out your pack types and cell counts to narrow the field. If quick charging are important to you don't get hung up on ports as the max amps of all the top rated are nearly the same. If your going to spend alot of money it would be wise to get a charger than can tell you at any point during charging or discharging what ampacity and current rating is going in/out at any point in time during the charge. This is great for contest's as the use becomes predictable therefore between round charging becomes an easy method to determine your batteries characteristics of use and when something is strange it may just well be..........
Another wise feature is to get one that will top off with a trickle charge once the peaks have been detected and tripped off the charging circuit. Otherwise your bateries will never see a complete 100% charge capacity.
Old 01-17-2004, 07:42 PM
Panzlflyer
My Feedback: (15)
Panzlflyer's Avatar
I have run the Schultze and Triton and Fma and Super Turbo .....all will operate on a 3 amp power supply BUT if you want their FULL charge outputs then you need a bigger supply. The same is true off ALL of them.
None of these chargers is a Generator. (Including the Miniron)
What goes into the battery must come from somewhere and if you are charging reciever packs 10amps is overkill.
There are quite a few power supplies out there for $20 to $50 that output 10+amps.
Old 01-18-2004, 12:42 AM
c/f
"None of these chargers is a Generator".
How about 38VDC from a 12VDC deep cycle battery, charging at 8 amps on a Schulze!!!
Something went terribly wrong adding to the mystery/dangers of Lithium Poly use.
Was a brushless motor FUNTANA originaly ..................
Old 01-18-2004, 09:02 AM
Panzlflyer
My Feedback: (15)
Panzlflyer's Avatar
Stepping up and down voltage does not electricity make.
It was the amp issue I was on about. Other than the Electric guys most people are charging small receiver/transmitter packs and are under the impression that they must have the biggest power supply around which is not true unless as in your case they need it.
Old 01-18-2004, 10:00 AM
Forgues Research
My Feedback: (7)
ORIGINAL: andyt
Andy,
When I was reffering to the miniron with 5 outputs, I was not stating that they could charge at a high output for the electric guys.
These chargers are for the non electrics, eg. Jets, large scale aerobatics, large scale warbirds etc. where you need to charge many batteries.
Roger
