LiPo 7.4v For Receiver Battery?
Can I used a 2S LiPo 7.4v battery for my receiver battery? This question pertains to late model Futaba and Spectrum receivers and Digital servos (not the High Voltage servos). This has been a topic of discussion in our flying group. Some guys say they are doing this and it's working fine. Some others say you need to use a voltage regulator to drop the voltage. Is anyone out there running unregulated LiPo 7.4v packs? Any information on this would be appreciated.
Best Regards
JC
I don't always fly R/C...but when I do, I fly FASST. Fly well my friends.
Best Regards
JC
RE: LiPo 7.4v For Receiver Battery?
Thanks Sid. I'm agreeing with you. Just wanted to see if this is working for other fliers out there.
Regards
JC
Regards
JC
The Rx "may be ok" (I would not do it) but the servos will burn out if not high voltage. Most current Rx have a regulator inside but output to servos are not regulated. I personally would use a regulator if using 2s LIPo. You can use unregulated 6.6v (2s) LiFe( A123) to Rx and most servos that are rated for 6v (meaning rated for 5 cell NiMH or Nicd) will be just fine. Lots of discussion about this in the jets forum if you do a search for it.
Good luck
Good luck
Not sure 8.4V, full charged Lipo is safe for your electronics. I wouldn't chance it. However I do use a 2s Lipo in my Futaba 6J transmitter but with a 1N4001 diode (cheap and available at Radio Shack) in series with the pack. It drops the voltage about 0.8V. The 6J normally uses 6V alkaline battery set. I don't know how well your rcvr/servos will work as the battery discharges. The 0.8V drop could be a problem.
IB
No, they do not.
A LiFe, or A123 pack will come off charge at about 3.6V and drop to its nominal voltage of 3.3V per cell very quickly.
Pete
Pete
Using a resistor would be highly unsafe. As it acts as a current limit, the voltage dropped across it will vary wildly. Typically if a 100 ohm resistor is used it may vary from 1v at rest to 4v when 4 servos are active, see ohm's law. If you know anyone using a resistor bring a dustpan and brush.
