Foam cutting
My Feedback: (18)
It will output up to 8 amps when charging. Not sure about the max output when cutting foam. However, I have turned it up high enough to melt the wire by mistake.
The Astroflight 110D can often be found CHEAP at swap meets or auction sites as it charges only Nicad batteries and most people have only Lipo these days. Not many know of it's foam cutting capabilities. Several other Astroflight chargers will also cut foam, you'll have to root around on the web for more info as I don't remember.
