Receiver& ignition on same batter
My Feedback: (58)
VA
I am thinking of running both ign.& receiver off the same 2100 mah. hobbico life battery with duel leads on the batt. Any problems with R.F. if I try that? I will get a good range check with engine running before I would try to fly it. Anyone tryed this? Thanks Wayne M.
I run all my gassers with a single LiFe battery, but I wouldn't do it without using an IBEC to provide filtering and current limiting if the ignition module was to short and put a big load on the battery.
Pete
Pete
Tech-Aero Designs LLC
This one seems to be the most popular. Being able to turn the ignition on/off from the radio is worth the cost alone
Pete
Pete
My Feedback: (58)
VA
I built a voltage reducer with a bridge rectifier In a 6" extension. I plan to fly it satuday with two life batteries instead of one with two leads for now. I will try the ibec later. Thanks to all that helped. Wayne M.
NC
I use the Rcexl Opto gas engine kill switch.. I put a diode in the rcexl opto kill switch.. I'm running two JR leads out of the A123 battery pack.
#1 to RX and #2 to the rcexl opto kill Switch thin to the ignition system.. Been running this config for a year without a problem.
My Feedback: (58)
VA
where can I get the same diode that you used and what is the name or brand of diode? I have a Rcexl kill switch on my engine. I had decided to use two batteries for now. Maybe look to get a ibec later. Also did you put the diode before the power comes to the kill switch or between the switch and the Ign.? Thanks Wayne M.
NC
Diodes
1N4001 this is the one I use... diodes are silicon based and have approximately .7 volt drop. Look for diodes at Radio Shack.
diode 1N4001,1N4002,1N4007,1N5402 ....the last number is a reference for the max or breakdown voltage. Each diode has about .7v drop so if you wanted 1.4v drop, you would put two in series. Make sure you reference the "line" on the diode in the right orientation. The line denotes the cathode or the "negative" side. You want this cathode line facing the ignition... The side without the line going to the battery or supply voltage..
Not trying to hijack the thread, but I have a question. I am working on a Pulse 125 with a DLE20. I was going to go the 2 battery route, but this seems so much better and saves space as well. I am used to installing a mechanical switch with a charge port so I can just plug the plane in for charging. If I use the IBEC to go to one battery, do I have an option to still charge the battery still in the plane and an external port?
NC
Yes you can just plug the plane in for charging. Balancing is important too with A123.. But not a must for every charge.. Balance charging at home is what i do...
GA
I do what Jerry RCU is talking about............I only Balance charge every 3 charges....I Balance charge at home so even if I fly a lot on a day a second charge at the field really does not require a balance. Last I have 8 inch balance leads extensions(coiled u[ in the fuse) that can be used if I fell I need to balance at the field......I just pull these leads out of the fuse after a quick canopy removal. Hears a pic of the 8inch extention attached to the batts left in the fuse.
NC
Checklst is right.. You do not have to balance charge every time.. I have a separate plug-in balancer for A123s.. DapterRx is specifically designed to charge AND balance 2-cell A123 (LiFePO4) receiver packs.
Heres a link to the DapterRx and Astro-Flight
http://www.slkelectronics.com/DapterRx/index.htm
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTPG1
CA
Use an opto kill switch with BEC. I use this one, http://www.valleyviewrc.com/estore/r...-shipping.html
For charging, you can use your regular charge port on a heavy duity switch. Use the signal wire as your 3.3V tap. Hang time hobbies gives details, or can sell you the parts made up already. Hangtime has tons of informaiton. They are a must read site, check them out. Basically you remove the signal wire on the plug, on the receiver side. On the charging side you use it as a tap. You then make up a charge harness using the regular servo lead plug.
I have made the transition to LIFE for all my RX packs. IT is wonderfull to not have to worry about my RX packs loosing charge over time like the NIMHs did.
I wouldn't use the same battery for the ignition and receiver. If the ignition shorted out and drained the battery you wouldn't have control on the aircraft. I'm a fan of redundancy. Why take the chance?
