New Hitec charger and power supply dock together
#44215 : $84.98
Hitec’s new X1 Pro DC/DC battery charger delivers a powerful 180 watts to your Lithium-based, NiCd, NiMH and Lead-Acid batteries. With an adjustable charge current rate of 0.1~16 amps, this single port powerhouse provides exactly what your hobby demands in the workshop, at the field or in the pits. The X1 Pro design includes docking capability with the ePowerBox 17A power supply upping its ante in convenience and portability.
http://www.servocity.com/html/hitec_x1_pro_charger.html
Specifications:
Input Voltage Range: 11~18 Volts DC
Charge Circuit power: 180 watts
Charge Circuit range: 0.1 - 16.0 amps
Discharge Circuit range: 0.1 - 8.0 amps
Discharge Circuit power: 30 watts
LiPo, LiFe & LiIon Circuit Drain: 200mA per cell
NiCd/NiMH Battery cell count: 1-15 cells
LiPo/LiFe/LiIon cell count: 1-6 cells
Pb battery voltage: 2-20V
Net weight: 14.3 oz (0.89 lbs)
Special Features:
- Compact and Unique Design
- Two DC inputs
- Optimized Operating Software
- Internal Independent Lithium Battery Balancer
- Balancing Individual Cells During Discharging
- Adaptable to Various Types of Lithium Batteries
- Fast and Storage Mode of Lithium Batteries
- Cyclic Charging/discharging
- Battery Memory
- LiPo Battery Meter
- Re-Peak Mode of NiMH/NiCd Battery
- Delta- Peak Sensitivity for NiMH/NiCd
- Automatic Charging Current Limit
- Capacity Limit
- Temperature Threshold
- Processing Time Limit
- PC Control Software “Charge Master”
This charger is powered by an 11-18V DC power source. There are two pair of DC input sockets: One is used for the connection of a DC power cord (XT60) type connector and is located on the right side of the charger. The other is used for docking into the ePowerBox 17A Power Supply and is located on the bottom of the charger. This socket accepts banana plug type connectors.
ePowerBox 17
This extremely efficient power supply converts 100~240 AC volts into 17 amps of continuous 13.8 volt DC power, making it compatible with a wide variety of DC chargers.
#44216 : $99.98
http://www.servocity.com/html/epower...ng_power_.html
Specifications:
Input Voltage Range: 100~240 Volts AC
AC Input Voltage Frequency: 50-60Hz
Output Voltage: 13.8 Volts DC +/- 0.2V
Output Current: 17 Amps +/- 0.5A
Current Overload Protection: > 17.5A 55ms
Input Current Protection: 5A Fuse
Output Voltage Ripple: <150mV
USB Ouput Voltage/Current: 5V / 2.1A
Power Efficiency: 91%
Power Factor: >0.98
Temperature Protection Cutoff: >65ºC
Cooling Method: Temperature Controlled Fan
Operating Temperature Range: 0-40ºC
New Weight: 21 oz (1.31 lbs)
Dimensions: 5x3.6x2 inches (125.7x92.7x50.2mm)
Special Features:
- Wide Voltage Input Range of 100-420VAC for Worldwide Operation
- Active Power Factor Correction for a Lower AC Input Current and Less Interference
- Lightweight and Compact
- Two DC Power Outputs
- ON/OFF Power Switch
- 9 LED Indicator Lights Display Output Current Draw
- Built-in 5V/2.1A USB Power
- Smart Fan Cooling System
- Temperature Protection Circuit
- Built-in Safety Features
- Works Seamlessly with the X1 Pro Charger
