mixing receiver batteries in a two battery set up....?
My Feedback: (14)
AL
I have a large scale Super Sportster with a 30 Gas DLE... I purchased it from a friend and it is set up with two NiMh batteries ..each 4 cell.... One of the batteries is not taking a full charge and runs down to quick... I have a good 5 cell NiMh battery that I could use in this two battery set up... can I mix the one 4 cell with one 5 cell... each with connections in the receiver... This set up has worked very well for 2 years until now and the one cell is not holding a good charge...
Are there any concerns that I should have with a two battery setup in one receiver....?
If one of those old cells are failing, the rest are not far behind. If you value your plane, replace all the batteries with known good ones and save yourself a lot of greif
GA
http://www.hobbyking.com/hobbyking/s...iver_Pack.html
My Feedback: (82)
OH
You can buy a BEC (Battery Eliminator Circuit) and run your DLE ignition off the Receiver pack...I do this in my 30cc gas birds because at that size and below it really does add a good amount of weight to have two batteries,wires,switches, etc.
My Feedback: (27)
ID
I use Hobbyking 6.5 volt (two cell) a 1100 ma for ignition and a 1700 for receiver, in a DLE 35 ra, Escapade MX. works well, charges fast and is inexpensive. Any doubtful packs should be quickly discarded, no exceptions.
