Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Fire Proof Lipo Vault
Old 03-06-2018, 08:42 AM
cyclops2
cyclops2's Avatar
Agreed.
Old 03-06-2018, 10:53 AM
Propworn
Propworn's Avatar
AHHHH BoBo up until now it was only speculation that CA fumes can slow comprehension. I would recommend an open window or fan perhaps.
Old 03-06-2018, 11:12 AM
init4fun
init4fun's Avatar
yep , just say no to drugs ....
Old 03-06-2018, 11:15 AM
init4fun
init4fun's Avatar
Hey , Crackhead , have you wondered why the response hasn't exactly been , , overwhelming at your "road trip" thread ? Maybe they've all read your twisted posts here and want no part of you at their fields ?
Get some help dude , you got some serious issues ....
Old 03-06-2018, 11:37 AM
Propworn
Propworn's Avatar
AWWW now ya done hurt ma feelins LOL!!!!!! Such a droll personality LOL!!!! Go ahead you can have the last word I have a cabinet to build and a garage cat with more personality and smarts than spend it bantering with you. Been a slice LOL!!!
Old 03-06-2018, 12:36 PM
  #31
sosterhaus
Default LIPO Smoke, heat but no fire
Last fall when charging a 3s LIPO, when checking smelled a faint odor but didn’t think much about it. About 10 minutes later smell was pretty bad and then battery began smouldering and lots of smoke so with BB tongs disconnected from charging unit and tossed it on concrete drive. Took quite a while for it to go out and couple hours to cool - man it was hot yet no flames. When checking afterwards, there was a lot of gel like substance oozing out (that stunkj from a small brad size hole in the end. Looked in plane that it was last flown in and noticed a bolt through firewall that held motor mount that matched up to hole in battery that I suspect was the culprit. Morale of story is to protect battery compartment.
Believe that couple ammo boxes will be in the garage this spring before flying season as a precaution and batteries will be inspected closely prior to charging. It was an eye opening if not frightening experience.
Old 03-06-2018, 12:48 PM
  #32
init4fun
init4fun's Avatar
Originally Posted by sosterhaus
........... Looked in plane that it was last flown in and noticed a bolt through firewall that held motor mount that matched up to hole in battery that I suspect was the culprit. Morale of story is to protect battery compartment.
Oh yes , a hole in the wrapping will let air in , and LIPOs don't like air in them one bit . You make a very good point (no pun intended) of making sure there are no sharp protrusions in the battery compartment that can compromise the battery's covering . Overcharging , overdischarging , and physical damage sure seem to be the big three in LIPO destruction ....
Old 03-06-2018, 03:37 PM
  #33
cyclops2
cyclops2's Avatar
I had to use Velcro on all batteries to keep them in place. But too much Velcro. Is tough to remove from a small foam compartment
Old 03-06-2018, 04:04 PM
  #34
sosterhaus
Used Velcro as well - straps and pads. But very tight space and probably on landing may have moved a bit that caused the problem. Enlarged the area a hair and added a small piece of ply to protect in future.
Steve
Old 03-06-2018, 05:21 PM
  #35
cyclops2
cyclops2's Avatar
I also have a thin scrap of wood, plastic or metal epoxied to foam surfaces to prevent rip outs.
Old 03-07-2018, 07:17 PM
  #36
elmshoot
You make a great point and something that I have seen plague glow motors when the fuel tank rubs against the mounting bolts.
Sparky
Old 03-12-2018, 12:37 AM
  #37
rcfunfan
what about a lipo safe bag made of fiberglass material?
Old 03-12-2018, 04:19 AM
  #38
cyclops2
cyclops2's Avatar
Problems occur when the batteries get more powerful. No one can specify which bag will contain a RAPID full blown fire with any size battery. Someone can post the temperatures of a full power ignition.
Old 03-12-2018, 06:45 AM
  #39
tntpooof
tntpooof's Avatar
cyclops. punch some small holes in can lid then use 100 monofilament to hold it up it will melt if a lipo goes up..A123 will not fail like a lipo..id remove the steel screen might short and kill the A123's.
TO WORM.. your clueless idiot STFU >> i have seen more NIB 1st charge lipos go up than used.. only thing worse is a damaged lipo..
A batbox will contain any lipo that runs away..http://www.bat-safe.com/web/
Old 03-12-2018, 07:50 AM
  #40
cyclops2
cyclops2's Avatar
I have never flamed a LIPO. Even after a bad crash.
My chargers go to a very low current rate if any cells are uneven. I am never in a hurry with battery charging. I let the charger do the trickle routine.
Old 03-12-2018, 09:47 AM
  #41
tntpooof
tntpooof's Avatar
This statement shows you you are totally clueless in the way a charge is done.. trickle charging a lipo lol.moron..Dont trickle charge a lipo very dangerous..
Old 03-12-2018, 10:24 AM
  #42
cyclops2
cyclops2's Avatar
The only dangerous thing is you.
Old 03-12-2018, 12:55 PM
  #43
Propworn
Propworn's Avatar
A batbox will contain any lipo that runs away..BAT-SAFE » Safe lithium battery handling
Hey init4Fun here's a wingman for ya!!!!!!!! LOL sorry I couldn't resist my bad.
Old 03-12-2018, 02:20 PM
  #44
init4fun
init4fun's Avatar
Oh no no my friend , I never play with explosives ....
Old 03-13-2018, 08:11 AM
  #45
Propworn
Propworn's Avatar
AWWWWWW come on bet you guys could give these two a run for their money LOL
Old 03-13-2018, 11:27 AM
  #46
init4fun
init4fun's Avatar
I saw Jeff Dunham back before Achmed had a Son , tic tic tic BOOM !
Old 03-20-2018, 06:16 PM
  #47
cyclops2
cyclops2's Avatar
I like the picture in the BAT SAFE photos. all those batteries together.
Safety in numbers ?
