Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Reload this Page >
NiMh battery+Hobbico Accu Cycle Elite charger question.
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 05-03-2018, 09:40 PM
Kostas1
Kostas1's Avatar
Default NiMh battery+Hobbico Accu Cycle Elite charger question.
Dear friends,
I am using a Hobbico Accu Cycle Elite charger for almost a decade now and I'm very happy.
I recently got a Futaba 8J and I had to order a custom 4/5AA NiMh 5Cell pack to fit on the battery compartment.
Unfortunately,
when I am trying to cycle the pack to refresh it i get a time limit warning and the readings on the charger are:
Minutes before warning: 7.33V @ 1.766mAh
On warning: 7.23V @ 1.800mAh
The battery pack consists of: 1.2V NiMh at 1.200mAh
Do you have a suggestion?
Old 05-04-2018, 04:16 AM
BarracudaHockey
BarracudaHockey's Avatar
Are you trying to cycle it in the transmitter? Most have diodes that prevent discharging thought the charge jack.
Old 05-04-2018, 04:25 AM
Kostas1
Kostas1's Avatar
No,i removed it from the battery compartment...
Old 05-04-2018, 04:49 AM
Jesse Open
Jesse Open's Avatar
You are remembering to set the switch at the 5 cell setting? If so, it could be dirty switch contacts. Slide switches are prone to that problem at times.
Old 05-04-2018, 04:55 AM
Kostas1
Kostas1's Avatar
I think yes,i set it at 5 cell.
Old 05-04-2018, 10:02 AM
A. J. Clark
A. J. Clark's Avatar
Maybe you just don't have all the steps programmed for the discharge cycle. Along with cell count you need charge amps, discharge amps, and cell volt cut off
Old 05-04-2018, 10:16 AM
Kostas1
Kostas1's Avatar
To be honest,
I haven't changed anything because the charger auto-detects whats best for the pack.
I only chose 5cell & the 1200mAh's capacity.
Old 05-04-2018, 11:10 AM
BelAirBob
Hi
i have this charger and same issue at times. I think it has something to do with not detecting the peak
Old 05-04-2018, 02:52 PM
A. J. Clark
To be honest,
Yes that is true. Good idea to check all the settings anyway. Maybe make some miner changes and try again .
Old 05-04-2018, 04:27 PM
bhorton
My Feedback: (26)
I had the same problem. I set the peak sensitivity to 3mV and it solved the problem.
Old 05-05-2018, 10:58 PM
Kostas1
Kostas1's Avatar
OMG, thanks for your suggestion, i've never thought of that!
I will see whats going on with the 3mV sensitivity and report back.
Meanwhile,
I am copying this from the manual of the charger:
Press DOWN to find the PEAK SENSITIVITY screen. This value determines the sensitivity/accuracy of the peak detection circuit. The factory default value of 8mV is acceptable for NiCd and NiMH batteries. Adjustment of this value can help match the characteristics of your battery to the charger for better peak charges. The recommended settings are 5-15mV for NiCd batteries, and 3-10mV for NiMH batteries. A lower number means the cycler will try to be more precise in finding peak charge, but in certain situations could cause the cycler to errantly stop peak charge too quickly, in which case it may be necessary to increase this number to 8mV or greater (especially if using AC input power). Press CHANGE, then UP or DOWN to find the desired peak sensitivity value. Press CHANGE to confirm selection.
