Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Reload this Page >
accidently discharged my life battery
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 08-02-2021, 04:04 AM
Dwayne
Default accidently discharged my life battery
As stated I accidently fully discharged my 3000ma life battery I use for my receiver/servos, when I put it on my charger it said voltage low and wouldn't charge it so I had to use NiMh to get some voltage in it before switching back to LiFe function, the battery is fairly new maybe 30 flights on it, never been run down before and I charge it after every flying session, so did I kill it? Or is it still good?
Old 08-02-2021, 05:16 AM
BarracudaHockey
BarracudaHockey's Avatar
They are pretty tolerant, i'd keep an eye on it and if you're really worried make it a bench battery for setup and testing but it's probably fine
Old 08-02-2021, 01:54 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Probably fine on a LiFe
David
Old 08-03-2021, 11:59 PM
Lifer
Lifer's Avatar
How much did the battery cost compared to how much the plane costs is the question I always ask.
Old 08-31-2021, 07:54 AM
fovoje
I don't think that this is such an issue, right ?
Old 08-31-2021, 03:45 PM
thomb81
I did the same to a brand new $110 6S LiPo battery once. Was able to recharge by briefly putting the charger in NiMH mode before switching back.
My battery appears to take the same amount of charge as before. But I don't know if it's damaged and could let me down under heavy load. I did fly it once though, and didn't notice anything.
If you cycle it with realistic loads, and it behaves like normal without getting hotter than your other batteries, maybe it has survived? I don't know...
Old 08-31-2021, 03:57 PM
BarracudaHockey
If you have a charger that shows IR of the cells you will know if you killed it or if its good to go
Old 10-04-2021, 05:23 PM
cyclops2
cyclops2's Avatar
Default I try to destroy my A123 cells that are from when Black & Decker sold them in their o
I run 1 very old pack down to .25 volts sometimes in a vacuum cleaner. It is still at 90 % on all equal cells. A shotgun will kill them. But nothing else that is reasonable.
