internal resistance, imax b6 v2
i just got myself a imax b6 v2.
the charger can measure the internal resistance of the cells. however the reading is very different than manually measuring it.
i took a few measurements with the b6 v2 (they're always a bit different with the same battery)
then, i measured the internal resistance manually using a 1ohm resistor and ohm's law and kirchhoff law.
what's your experience guys? can the b6 v2 mesure internal resistance of cells accuratly?
I bought the "ESR/IR Mark II meter" and that is considered to be the "Gold Standard" for measuring ESR and IR and will also give an estimate of the pack's "true" C-Rating
Progressive RC has them.
But, you can read more about them here:
The official new ESR/IR Mark II meter thread – NB: READ THE FIRST 10 POSTS - RC Groups
