ISDT K2 Air Bluetooth problem
Hi All,
I have a new ISDT K2 Air charger with the ISD Link app installed on my iPhone. Despite the app showing K2 Air on it when I attempt to add it the app times out. I've tried this a dozen times with still the same problem. The iPhone shows 'Central' in the list of Bluetooth devices if that helps.
Does anyone know what's going on?
Cheers
Daz
Cheers
Daz
My question to you is: Did you "discover" the charger in the phones "Bluetooth" screen yet?
You have to open the "Settings" app, then press the "Bluetooth" icon. Then turn on the charger and use its menu to make it discoverable to another Bluetooth device (like your phone). After a few seconds, a new Bluetooth device will show up on the phone, and you click it. It should ask if you are pairing with it, and it may have a 5 or 6 digit code you'll need to enter before it will pair.
Once it's paired, close the Settings app and then open the charger app on the phone. It should find it in a few seconds.
