Attn: Hobbico Elite Owners
#276
My Feedback: (16)
GA
RE: Attn: Hobbico Elite Owners
To check it, hook the meter in line and when you are charging the pack (1.0 amps) check to see if the current flowing to the pack is 1.0 amps. I did this check on my system and measured 200ma at 202.5 ma. This is close enough for me.
As far as how to calibrate it?
I would send it back to Hobby services with your readings.
Also make sure your meter is good.
Also check to see that the math is right.
If you charge at a particular current for the amount of time specified, make sure that the capacity reading matches the math.
ORIGINAL: Francis Fernand
Geistware,
I do not have any meter, but I can get one.
How do I know if the Elite is not calibrated ? or How do I calibrate the Elite ?
Thanks in advance,
Geistware,
Thanks in advance,
