Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Help 6 volt in rambler
Old 10-20-2004, 01:18 PM
rob6894
Default Help 6 volt in rambler
Hello all I purchased a seeker II receiver for my new Rambler 45 at that time I ordered a 6 volt battery for the rx my servos are rated for both 4.8 and 6 volt. I thought I was doing a good thing by going to 6 volt but know I am reading about needing regulator and better chance of failure. Is a regulator needed? Am I asking for trouble? Will I be ok? Don't know if it is helpful but I have6 servos in the plane Hi-tec for the throttle and retracts and futaba for everything else.
Please help before I install.
Best,
Robert
Old 10-20-2004, 11:18 PM
rob6894
Default RE: Help 6 volt in rambler
I really need help with this.
Old 10-21-2004, 06:00 AM
pettit
My Feedback: (23)
pettit's Avatar
Adding a voltage regulator just introduces several more failure points into the already complex system.
Keep things simple. Use the 6 volt battery and see how the radio system performs.
Remember you need a 5 cell charger.
Old 10-21-2004, 09:34 AM
rob6894
Thanks for the info. Do you think I will do any damage without one all the equipment says it supports 6 volt. This is my second plane and has not been flown yet so I am being a bit cautious.
Best,
Robert
