Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Reload this Page >
Adapter to charge LiPos from any charger
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 05-25-2005, 10:53 AM
Red Scholefield
Banned
My Feedback: (9)
Default Adapter to charge LiPos from any charger
The people at ElectriCalc have introduced a device, the LiPoDapter that enables you to safely charge Lipo packs (2 to 6 cells X 5 amps) from your Ni-Cd/Ni-Mh charger.
See: http://www.slkelectronics.com/lipodapter/index.htm
We have tested this at the Battery Clinic and found it to work as advertised on a number of different chargers.
Old 05-25-2005, 11:18 AM
guver
My Feedback: (325)
Default RE: Adapter to charge LiPos from any charger
That look pretty good, how do I contact that company. There's no contact info.
Ha this puts me one step closer to li-po....
Old 05-25-2005, 11:22 AM
Red Scholefield
Banned
My Feedback: (9)
ORIGINAL: guver
You can order from the web site: http://www.slkelectronics.com/lipodapter/index.htm
or if you need to contact directly
Sid Kauffman
SLK Electronics
2906 Charolais Drive
Greensboro, NC 27406
336)676-1681
FAX: 676-9707
[email protected]
Old 05-25-2005, 11:58 AM
guver
My Feedback: (325)
Thanks, Red
Old 06-08-2005, 10:49 PM
RChobby53
Red, would this device work with an Alpha 4? I know it has some special pulse routines that might confuse it.
Old 06-09-2005, 04:59 AM
Red Scholefield
Banned
My Feedback: (9)
ORIGINAL: RChobby53
I have used it only on the N function with the Alpha 4.
Further testing on the LiPoDapter indicates that it does not fully charge the pack when a 1C rate is used. We suspect that this is because the current does not taper off as it approaches the cut off voltage as is done in other Lithium chargers. One would have to reduce the charge rate manually or reconnect at a significantly reduce rate to bring the charge to a higher level.
