Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Reload this Page >
Multiplex LN-5014 Charger Ships & Review
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 08-12-2005, 08:50 PM
mglavin
My Feedback: (31)
Default RE: Multiplex LN-5014 Charger Ships & Review
ORIGINAL: BCer-RCer
The instructions for programming Li-Po state "" In this menu the nominal voltage of the battery to be connected for charging and discharging can be set using the INC and DEC buttons. Possible values are 3.7V, 7.4V, 11.1V, 14.8V and 18.5V."
If I were to have the setting at 11.1V, but only have a 2 cell Li-Po connected, would the charger auto detect the 2 cell pack, and not attempt to charge it as a 3 cell (11.1V) pack?
I tested your question with a charged two cell Li-Po and found that the battery attempted to charge for a minute or so at a very low rate (,20) and then the charger honked, buzzed and said LOW VOLTAGE error while shutting down! So I guess it’s safe to assume it recognizes it’s not a three cell battery by virtue of the cells voltage, the inverse is true as well charging a three cell pack with two cell parameters.
Regarding charging at 0.7C ( which for a TP 2100 ma pack would be 1470 ma I believe )
Lets say you have a 1000 ma capacity pack and want to charge it at 0.7C You're saying to input 700ma as its capacity. Does the charger not stop the charge at 700ma? This would mean having to restart the charger to get a full charge. Would this work OK?
The capacity rating dictates the charge rate and the charge passed to the battery. I tested by setting up a 2000mAh Li-Po at 200mAh capacity, been charging this evening now for 66 minutes at .20 once the battery adsorbed 220mA the charge terminated. I don’t see a problem with sequencing multiple charges to reach full charge at low charge rates.
1C is the maximum charge rate, so I'm thinking that charging at less than maximum might increase the life span of the packs. Don't think I'm alone on that thought. At home I'm in no rush, so why not charge at a lesser rate.
There is NO doubt that charging at lower rates extends battery life. It’s well known IMO.
Old 08-12-2005, 11:40 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
How reliable and accurate is the peak detection when slow charging a NiMH Tx or Rx pack ? Thx
Old 08-13-2005, 02:23 PM
Josey Wales
My Feedback: (61)
Josey Wales's Avatar
Ive got one on the way!
Old 08-15-2005, 03:38 AM
MoJoe
OK I finally got mine. Here is my review.
Cost $83.95
Good Looking small silver case - ver small!!!!
Easy to Use
Relatively Cheap
Back-Lit Display
Does 14cells
Does PB, Nicd, Nimh and Lipos
Cycle batteries up to 5 cycles
Dislikes:
When in Cycle mode, when it finish each cycle it doesnt keep record of the amps charged;
Would like more charge cables;
Overall Rating
9/10
Old 08-15-2005, 08:50 AM
mart242
MoJoe,
Do you have / have you tried other chargers? Especially the Triton?
I think that a few people in here (including me) are hesitating between a Triton and a LN5014. I've got a LN-5014 on order, but could still switch for a triton..
Old 08-15-2005, 09:23 AM
  #31
MoJoe
ORIGINAL: mart242
MoJoe,
hi marty.... this is my first "real" charger....
having the option, i probably would pay the extra $30-$40 for a triton or a Duratrax Ice .... just coz of their extra features that i listed above that the 5014 doesn't have.... especially now that i am going from Nitro to Electric racing...
Old 08-15-2005, 10:02 AM
  #32
Texan
My Feedback: (10)
Texan's Avatar
I've used the LN- 5014 for a few weeks now. My application is primarily e-flight. I have a full featured charger (with memories) that is my primary field charger. However, I have found myself using the Multiplex more often. I'm not sure if that is because it is newer or easier to use. I would consider this to be a niche charger; a major step-up from beginner e-flight chargers like Hitec CG340 or Multiplex LN2010 without the extra expense of a Triton. However, the LN-5014 offers a good deal of flexibility and user friendliness without some of the extras found in the Triton. Multiplex seems to have kept the essentials of a solid e-flight field charger while eliminating the features that drive cost higher.
Old 08-15-2005, 10:54 AM
  #33
mart242
THanks for the info guys.
I've got a glow helicopter but might go electric some day (t-rex, or something small). Would I miss something by not going to the Triton? The last thing I want is to find out there's a feature that I need but is only available on the Triton. I'll spend the extra $$$ to go for the Triton if it's a better charger.
Old 08-15-2005, 11:10 AM
  #34
Texan
My Feedback: (10)
Texan's Avatar
ORIGINAL: mart242
Mart242,
It's not worth loosing sleep over if you don't mind spending the extra $$$. Get the Triton. However, I believe the LN5014 is a great lower cost alternative. Personally, the only feature that I will miss is higher discharge rate for cycling. However, my e-flight packs get a lot of "cycling" in use.
Old 08-16-2005, 07:44 AM
  #35
MoJoe
edited
Old 08-16-2005, 10:18 AM
  #36
Texan
My Feedback: (10)
Texan's Avatar
MoJoe
The only time that I have had the problem that you describe is when the battery pack had a problem. Also, when charging a pack for the very first time, make sure that you charge it at the overnight rate. For your 1800 pack that would be 180ma, 10 hour charge. A lot of guys at our field getting into E-flight for the first time swear that their charger is bad because it false peaks on a brand new pack. I have found that some cells, specifically those with higher internal resistance (AAA nimh) definately can not be charged at high rate for the first time without false peaking.
Old 08-16-2005, 10:26 AM
  #37
mart242
ORIGINAL: Texan
My Triton is on it's way. It's proven, so I might has well play it safe. Most heli flyers around here have Tritons as well.
Old 08-16-2005, 10:33 AM
  #38
Texan
My Feedback: (10)
Texan's Avatar
Mart242,
That sounds like a wise decision. You will have a good pool of heli flyers to help answer questions regarding your Triton.
Old 08-16-2005, 06:53 PM
  #39
MoJoe
test
Old 08-16-2005, 07:29 PM
  #40
MoJoe
also i found in cycle mode, the user cannot secify the volatge with which to stop discharging.
i set it to 1.1 per cell on the discharge screen, however when i put it in cycle mode it goes below 1.1 per cell... i'm not sure what it goes down to... coz i stoped the discharge before i found out....
Old 08-16-2005, 10:18 PM
  #41
guver
My Feedback: (325)
The triton seems to be preset as well on the cycle mode. I have a question on this charger compared to the triton. Does it constant charge? or does it stop every minute like the triton?
That is one of my main dislikes about the triton. It brings the effective charge rate down to 4.5 instead of 5 really.
Old 08-16-2005, 11:43 PM
  #42
MoJoe
it seem like its linear...
Old 08-16-2005, 11:53 PM
  #43
guver
My Feedback: (325)
thanks, I do have the ice and is very good. I wish it would do more than 10 cells.
Old 08-17-2005, 01:08 AM
  #44
MoJoe
wanna swap bwahahah
Old 08-17-2005, 02:04 AM
  #45
mglavin
My Feedback: (31)
ORIGINAL: MoJoe
ok i have just used this charger a bit more.... i have been trying to charge 1800mah aa batteries... i charge 4 peice cradle... i charge at 1.5mah, and it charges for about 4 minutes, puts in about 140mA then stops... i try to chrage again and it stop again after 4 more minutes... it thinks its full and is just peaking it...
I am not sure what the hell is wrong... i now really wish i bought a Duratrac Ice!!!!
i have updated my review above [>:]
It's not the charger!!! I'll bet this is a NIMH battery? The charger is a Peak charger, the voltage peaks the charger senses this and shuts off, simple. You need to cycle NiMH several times to bring them up to capacity. Simply run at least three cycles and note the capacity after the last discharge cycle.
Old 08-17-2005, 08:41 PM
  #46
Panzlflyer
My Feedback: (15)
Panzlflyer's Avatar
You also might check your leads.
The Hobbico ones are 2 long and 2 thin to be much use and cause many a false reading.
Ive been useing this charger for a year now and it works well minus the memories etc as noted, With discounts the Triton is only a little more.
I have had false peaks from a Schultze, Triton, Ice etc etc they all will do it given the right circumstances.
Old 08-17-2005, 08:58 PM
  #47
Josey Wales
My Feedback: (61)
ORIGINAL: andyt
I thought they just started shipping them this month?
Old 08-17-2005, 09:07 PM
  #48
Panzlflyer
My Feedback: (15)
Panzlflyer's Avatar
If you look back thru the forums titled best value charger there was I think 3 other chargers all the same Multiplex just put their logo on it I posted a pictur of mine.
Dymond is one of them.
Old 08-17-2005, 09:12 PM
  #49
Panzlflyer
My Feedback: (15)
Panzlflyer's Avatar
http://www.rcuniverse.com/forum/fb.asp?m=3119474&key=
Old 08-18-2005, 08:05 PM
  #50
MoJoe
ORIGINAL: guver
for what application do you require to charge more than 10cells at once?
thx
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
