Is my battery pack toast????
New RC'er question: I just bought a used TC3 that came with a set of 3000 mah batteries. I put the pack on the charger and the readout siad it was only charging a 1.2 -1.5 amps, even though it was set at 3.0 amps. Within a 5 minutes the charger said the pack was charged. I put it in the car, the steering servo worked fine, but as soon as I applied throttle, the ESC powered up then stopped responding with in 1 second. Motor did not turn over at all. I put it on the charger again, and I got the same result.
What is the problem? Is the pack dead??? Please let me know your thoughts.
GA
RE: Is my battery pack toast????
which charger?
have you tried cycling the battery...
discharge at c/5, then slow charge at c/10 to approx 125% of capacity (takes overnight at least)
It's a fairly basic Duratrax Digital charger for both Nicd & Nimh. What is cycling? how do I do it?
I even hooked the battery directly to the motor (I'm sure this is a no no) and the motor didn't budge.
First - you need to get some information on how these batteries work so that you're not in the dark. A great site written by a guy who has spent his life developing these cells is Red's Battery Clinic. www.rcbatteryclinic.com Good stuff
Second - you'll need a DVM - digital volt meter. Measuring the pack voltage can tell you if it is completely flat or if the problem is elsewhere. Radio Shack has some decent ones for less than $30.00
http://www.radioshack.com/product.as...%5Fid=22%2D813
Third - a battery is a device whose output is measured in mAh or milli (1/1000) amp hours. Your 3300 mAh pack is capable of delivering 3.3 amps or 3300 mA for one hour or 330 mA for 10 hours roughly speaking. What I'm trying to say is there is a relationship between how much you draw in milliamps and time. This relationship also hold true for charging so if you only put in 1.5 amps for 5 minutes something is wrong.
Read up,
John
Read up,
John
My Feedback: (325)
sounds as if your charger is at fault and your batt and car are ok. It would be nice if you could find a close person or shop just top charge your batt for you once and then you would find ouit for sure.
My Feedback: (14)
ON, CANADA
ORIGINAL: mikehiggy
