Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Help a newbie with nicads
Old 10-26-2005, 07:24 AM
panzerd18
panzerd18's Avatar
Default Help a newbie with nicads
Hello,
I have just bought a JR 2610 transmitter with a 4.8volt 1100mAh (4N1100) receiver nicad pack and a 9.6volt 600mAh (JR-2S) nicad transmitter pack.
I have also bought a nice Swallow Advanced charger (http://www.modelflight.com.au/rc_mod...ry_charger.htm)
There are no instructions in the JR manual or the Swallow charging manual about the proper charge rates for my nicads. I am scared I will blow my nicads up if I use the improper charge or discharge.
The charger has peak detection and will charge from 0.1A - 5.0A and discharge from 0.1A - 1.0A.
In the manual it has an example of a nicad being discharged at 0.50A and being charged at 3.0A.
What is the general rule for charging/discharging rates for nicads?
Thanks for your help guys/girls
Old 10-26-2005, 07:47 AM
panzerd18
panzerd18's Avatar
Default RE: Help a newbie with nicads
I'm discharging the 1100mAh receiver pack now at 0.5A. The charger is getting hot.
Old 10-26-2005, 08:04 AM
Mad Wax
Mad Wax's Avatar
I would charge both packs at 100mah for the first few charges, then once used them for a bit charge at 300mah for 1100mah pack and 200mah for the transmitter pack. You're probably discharging a bit too fast since it's a fairly low capacity pack. Set to around 300mah discharge. Do a cycle/capacity stored check (charge, then discharge and note down the amount the battery has stored)
Old 10-26-2005, 08:34 AM
panzerd18
panzerd18's Avatar
Thanks for your help. It discharged pretty quickly on 500mAh. I am now charging at 100mAh like you said. On the screen the swallow is showing the battery at 5.591V. The pack is 4.8V so why is it at 5.591V?
Old 10-26-2005, 08:46 AM
Mad Wax
Mad Wax's Avatar
Charge rate voltage is higher than pack voltage, ie my TX pack 3PK is now charging @ 10.55V (8 cell)
edit now 11.19v (full auto NIMH mode)
Old 10-26-2005, 08:49 AM
Rodney
It may behoove you to check out Red's site www.rcbatteryclinic.com for good info on the care of all types of batteries, very good info for the newbe's especially.
