Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Scorpion Wiring?
Old 01-05-2006, 11:06 AM
cause i can
cause i can's Avatar
Default Scorpion Wiring?
Can we wire more than two packs of Scorpion in series or parralel to create varius power options? Will the lvc and balance sytems still function as designed?
Old 01-07-2006, 09:45 AM
Greg Covey
Greg Covey's Avatar
Default RE: Scorpion Wiring?
The Scorpion packs were tested up to 4 in series, making an 8S pack. There should be no limit in parallel configurations, keeping in mind current limitations of the connectors and wire. The ESC and receiver wires are daisy chained through each pack to ensure the LVC works on each pack. The charging must always be done on single pack disconnected from the system. This is due to the common ground of multiple chargers shorting stuff when connected to multiple series packs at the same time.
Old 01-07-2006, 09:59 AM
cause i can
Thats exactly what I wanted to hear. Thank you!
