lead acid batter charging with supernova
wondering if someone can help me. I have a supernova competition field charger. i have a RELY 12v7ah sealed lead acid battery for my field box. Can this charger be used to charge and discharge this battery. the power point charger is too slow. the charger can charge nicad, nimh lilon li-po i dont know if this battery falls uder one of these.
dan[:-]
dan[:-]
AZ
The only chargers I know of that can peak charge a 12 volt 7ah lead acid battery are the Great Planes Triton, and the MRC Super Brain 969 or 977 models, any of which will run around $100.00. If peak charging is not a concern, there are many 12 volt trickle chargers on the market that would suffice (although peak charging typically provides longer runtimes from batteries). You will want to charge that battery at no more than .2C (20% capacity) so a 7000mAH battery *.2 = 1400mA or 1.4 amps maximum charge current. Make sure whatever charger you use, you stay at that current or less to avoid possible cell damage.
OR
Yes, you can use the Super Nova 250s to charge your Pb battery. However, you can not discharge a lead battery. You must use the manual method for this charger. Default is set up to do Pb acid batteries on the 9th selection. It will shut off when done but it usually takes quite a while if your battery is really low. I usually charge at 1.5 amps.Tom
