Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
NiMH Charging problem
Old 01-07-2006, 02:18 PM
vinnie1024
Default NiMH Charging problem
Hi,
I have a Conrad batterypack 3300MAh 8 cell from CONRAD
and i charge it with a voltcraft Unicharger, When i, after discharging, charge it at 300mA it stops after 3 hours charging, so i am sure its not full. 300mA should be the normal charging rate.
What can / should i do?
pdf from the powerpack
http://www.produktinfo.conrad.com/da...r_Pack_AMP.pdf
http://www.produktinfo.conrad.com/da...150-1500mA.pdf
charcher
Vincent
Old 01-07-2006, 06:14 PM
Geistware
My Feedback: (16)
Default RE: NiMH Charging problem
Disable the peak charging function.
Are you connecting the pack directly to the charger?
Old 01-07-2006, 06:37 PM
vinnie1024
HI,
I doesn't have a function to turn that of.....
Yes, it's direclty connected to the charger.
