Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Can I charge a 6V (5cell) pack with JR Wall charger? >
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 01-20-2002, 01:13 AM
My Feedback: (12)
Joe McBride's Avatar
Default Can I charge a 6V (5cell) pack with JR Wall charger?
I have a 6V 1400mah pack and my JR wall charger is rated 5.8V and 150ma. Will this charger work?
Old 01-20-2002, 04:33 PM
nope, get a good quality peak charger and you can do all your batteries.
Old 01-21-2002, 03:46 AM
Jackjet's Avatar
Default Re: Can I charge a 6V (5cell) pack with JR Wall charger?
AAAA,
yes it will work-just check your output voltage of your wall charger with a dig. voltmeter -if it reads at least 6.80 to 7.50 vdc-you are good to go.
Jackjet
Old 01-21-2002, 02:09 PM
I strongly doubt it'll work. If he checks the output of the wallwart
w/o a pack connected, he'll get a falsely high reading. Once the batttery
is connected, I'm sure it'll drop to the 5.8ish rating which isn't enough.
Old 01-21-2002, 06:41 PM
Default Charging 6V pack
The output of the ordinary wall-wart charger is DC with a large AC component riding on top of the DC. As such, most voltmeters available to the hobbyist will not accurately give you any good information if you check the output unloaded. If you connect it to a battery load, the battery acts as a large capacitor smoothing out the DC to a point that a DC voltmeter will give you an accurate reading.
If you really want an accurate idea what the charger is doing, plug an aileron extension on to the charger output. cut one of the power conductors and insert the meter (switched to milli-amps) in series with the power lead. Plug the extension in to the battery pack and read the milli-amp output. If it is close to 140 mA you are good for a C/10 charge rate for your 1400 mAH pack.
Bob C.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
