How do you folks feel about the Duratrax Piranha DTXP4005?
IL
Hi
Wondered how you folks feel about this charger? Also, what does cycling batteries mean?
My Feedback: (325)
RE: How do you folks feel about the Duratrax Piranha DTXP4005?
It's a great buy. The worst thing about it is it's 3 amp limit on ac and it's limits chargeing higher cell counts on either ac/dc.
I think it is a better deal than nost $40 chargers unless you will exclusively use it on AC power.
Good value, easy to use.
Mine wouldn't charge 8 cells at more than ~1 amp though. No matter if i was on AC or DC.
I got one of these chargers, and I wanted to know what would be a good way to charge some brand new batteries. I have read it's better to slow charge them for the first time.
2400 mah NiCd - would charge at 1.2 amps for two hours
3000 mah Nimh - would charge at 1.5 amps for two hours
These would be for the first charge. Then I could up the amps for a quicker charge later after use.
I thought I have heard that peak chargers like this don't charge new batteries well and sometimes false peak.
I just want to get a good initial, full charge without blowing them up.
Thanks!
Thanks!
My Feedback: (325)
The slow charge for new batts cannot really be done by a peak charger very easily. It uses a rate od c/10 for 15 hrs.
On your batts it would be 240 ma and 300 ma.
ORIGINAL: U-dUd
Would I expect the charge to last 1 hour each respectively at those levels?
I know the max amps on AC current is 3 for this charger, so I'd expect no more than 1 hour to charge that 3000 mah battery, correct?
I know these may seem like basic Q's, but I have been out of the r/c world for about 15 years. The last charger I used I set for 20 minutes at the maximum amps to charge my 6 cell nicd battery. These peak chargers are all new to me. The directions on the charger seem easy enough to follow, but like I said before, I thought I had read peak chargers don't do a good job for the first charge, sometimes peaking too soon leaving a less than full charge.
Thanks for any advice.
My Feedback: (325)
Well, you are right about a peak charger not being able to do a "formation" charge because it is a 15 hr and forced charge. The peak needs to be ignored.
The charge will last 1 hr or so if the discharge rate is at 3 amps, same as the charge rate being at 3 amps will last for an hr.
It is a rate, like a 3 gallon bucket being filled or emptied at a rate of 3 gals/hr
AZ
ORIGINAL: Diesel Power
Hi
Hi
Now, I use it in conjunction with my MRC Super Brain 977 (aka. pimp-diggity-superfly-mac-daddy-of-batteries), and I can charge my radio batteries, receiver batteries, and 12 volt starter box battery all at once (since the Super Brain 977 can do two different packs/battery types at once).
Worst case, if every battery is totally dead, between the two chargers I am never more than a couple hours away (usually more like 30 minutes just to top them all off) from having everything charged.
As for cycling, look up the moderator Red Sholefield [sic], he knows alot about this subject.
EDIT: Here is the link - http://www.rcbatteryclinic.com
